battery cable
Discussion in 'International Forum' started by johnnydngrs, Dec 21, 2015.
  1. johnnydngrs
    johnnydngrs Bobtail Member
    16
    Apr 13, 2015
    hi all, i need alittle help. i change all four batteries on my 2010 prostar theres a wire that look to be connected to a fuse, does anyone know where this wire is from? did i accidentally bypassed the fuse or does it go this way. thanks
  3. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    If it's a red wire around a 4ga it probably goes to the Ecm
    johnnydngrs Thanks this.
  4. johnnydngrs
    16
    Apr 13, 2015
    thanks a lot, ill make sure i go thru the fuse
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Depending on what you have, if the fuse is cube shape then that cable is the main cab feed.
  6. johnnydngrs
    16
    Apr 13, 2015
    yes its a cube shape fuse the goes on top of positive battery terminal. i guess it a good idea to connect it to the fuse. thanks heavyd
