battery hook up
Discussion in 'Trucks [ Eighteen Wheelers ]' started by slowhand, Feb 6, 2016.
  1. slowhand
    slowhand Bobtail Member
    16
    10
    Jun 29, 2009
    Vt
    I took my batteries out in the fall and I neglected to mark which wire went where. Rookie mistake!!! I have a 3 battery system on a 1997 T600. Any info would be appreciated. thnx
  3. AModelCat
    164,971
    I would suggest getting a multimeter and checking continuity between the cable lugs and the frame. Whichever ones read 0 ohms or very close to 0 will likely be attached to the negative battery terminals. I would then follow the wires and confirm where they are going to just to be safe. Anything going to the frame/engine block etc should be a ground wire.
    slowhand Thanks this.
  4. Animosus
    Animosus Heavy Load Member
    734
    2,916
    Dec 7, 2015
    SE Wyoming
    Your batteries are wired in parallel. All the negatives hooked together and all the positives all together.
