Battery Issue --> here is where i found my problem - WOW
Discussion in 'Volvo Forum' started by JerryD13, Aug 6, 2017.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    Battery Issue --> here is where i found my problem - WOW -
    so you know where you turn off ALL power to your truck under the drivers side ..
    well there is a bolt BEHIND THAT not visible to the eye - THAT WAS LOOSE -
    symptom
    Poor Starts - weak start - battery was charged full -
    FIX
    Go spend 5 min -- and tighten all your battery cables down -- this is the source of many issues
    KB3MMX and G13Tomcat Thank this.
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    this is very true those switches have a lot of issues on these trucks
    KB3MMX and JerryD13 Thank this.
  4. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    Yep, battery isolation switches are an item to inspect. I had one fall apart on an International I sometimes drive.
