BC1 400 W2A vs A2A vs No Aftercooling
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Jan 10, 2026.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,416
    1,739
    Dec 4, 2019
    I’ll soon be approaching the tear down and build of a BC1 400, CPL 393. The goal, is modest, with around 450hp. I think the consensus would be to go with A2A. Bolting on an N14 intake manifold is a nonissue, however, this engine is for a IH 4070B, so there is lack of area to mount a charge air cooler, up front. Ive seen folks mount them on top of the frame behind the cab. The size of the charge air cooler matters but to what extent? I’ll probably run a HT60 on this unit, no matter what route I go.
    If I decide to leave it W2A, obviously it’s the original playbook, except for the HT60. I’ve had some folks tell me to rid myself of the W2A system, as it slows boost down. Implying, go with the HT60, plug off the coolant going to the W2A core or find an old NT style intake manifold and use it. Is there that much benefit on a BC, to have W2A vs. no aftercooling? Not any enormous hills or mountains in my area, my FIL is an experienced driver of old mechanical engines, so I’m not to worried about problems from excessive EGT’s. Truck will have a 15 speed and I believe, 3.73 rears, on tall 24’s.
  3. Oldman83
    Oldman83 Heavy Load Member
    861
    11,250
    Sep 5, 2024
    Marrowbone Ky
    My $0.02, I’d leave it W2A if space is an issue.
    There’s nothing “wrong” with W2A.
    It becomes a trade off. A2A is more efficient at cooling at road speed, but as you noted, space can be an issue. A2A does not have the advantage of warming up the intake air in cold conditions, and that cold air can really increase white smoke at idle on these old mechanical Cummins.
    W2A will be way better than mounting an A2A behind the cab where you have zero forced air flow across the cooler.
    No cooler at all would definitely be my last choice.
    @wore out is a Cat man, but would have valuable insight on this. @OLDSKOOLERnWV is a Cummins guy.
    Hopefully both these guys will chime in.
  4. AModelCat
    164,905
    In my own opinion I think you would be much better off with a W2A setup if you cannot get adequate airflow through an A2A to cool the intake air. I don't see you getting much airflow through a cooler mounted behind the cab.
    Oxbow and mile marker 27 Thank this.
  5. mile marker 27
    1,416
    1,739
    Dec 4, 2019
    I agree with air flow across and through the core. I’d think it’d still be cooler than air surrounding a core with 180-200* coolant.
  6. mile marker 27
    1,416
    1,739
    Dec 4, 2019
    I’m pretty sure I mentioned such a scenario about Cat’s before and woreout, suggested just leave the W2A alone if that’s what it has and the same if it was an existing A2A. In that instance, I was comparing a 7FB W2A 400 to, a 4MG A2A 400. I’m just asking the initial questions, as there may be some different facts or opinions, for BC’s.
  7. AModelCat
    164,905
    I don't know about that. I've read that the air going into an air to air can exceed 250 degrees under high boost. An air to air with no airflow to remove the heat is nothing more than a very expensive pipe.
    RGN Thanks this.
  8. wore out
    wore out Numbered Classic
    17,364
    215,623
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    You realize air flow is what cools air across the exchanger not the exchanger itself……
  9. Oldman83
    861
    11,250
    Sep 5, 2024
    Marrowbone Ky
    I’ve got pictures of a readout showing nearly 700° compressor outlet temperature on a compound turbo Cat at 60-65 psi boost. :D
    AModelCat Thanks this.
  10. AModelCat
    164,905
    I can believe it. Compressing air to make heat is the entire principal behind a diesel engine after all.
    Oldman83 Thanks this.
  11. mile marker 27
    1,416
    1,739
    Dec 4, 2019
    Yes sir, but the air behind the cab of a truck, is surely cooler than inside the W2A exchanger, on the side of an engine.
