Bearcat 880 Mic Problem
Discussion in 'CB Radio Forum' started by Arbelius65, Mar 29, 2020.
  1. Arbelius65
    Arbelius65 Bobtail Member
    Hi Guys, my son has a Bearcat 880 and hadnt used it in a while. Today we tested to make sure it worked via the CB in my truck. When I transmit, he can hear me clearly. When he transmits, I can see where he is transmitting because my bars max out when he presses his mic button, I just can't hear any vocalization. I can see where he is keying his mic but i cant hear his voice. The mic is one of those noise cancelling mics that come with the 880. Its like its cancelling not just background noise but his voice as well. Any settings that we are missing? Any ideas would be appreciated.
  3. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    He probably has a short in the mic.
    Ask him to wiggle the mic cord around while talking. Shorts or broken wires usually happens where the mic connector connects to the radio.
  4. Night Stalker10
    Night Stalker10 Road Train Member
    1,694
    1,267
    Jun 26, 2017
    Make sure his radios mike gain is turned up, if it isn't it can cause the problem you are describing.
  5. 25(2)+2
    18,756
    45,684
    Sep 18, 2006
    the road less travelled
    He should be able to see the meter kick up when he talks, if not, the radio isn't getting audio input from the mic, probably a short in the plug or cord causing that.
  6. Arbelius65
    Thats what I thought. I checked all wires in his mic cord for continuity and all good. You can see the meter on his radio spike when he talks. Also, when he talks, the meter on my radio spikes as well, just no voice coming through. Im thinking the mic in his mic is bad.
  7. volvo244t
    volvo244t Road Train Member
    1,779
    1,780
    Jun 24, 2010
    Bettendorf, IA
    Make sure the mic gain in the radio is set on 3, and make sure you talk with your lips right up to the center of the microphone (the bottom of the mesh section).
  8. mcarrara
    mcarrara Bobtail Member
    I've got the same radio with a similar problem when I key the mic it spikes, the gain is set to 3 but should I see the bars fluctuate when I talk or should it stay steady. I've also had a problem of the internal diagnostic sometimes passing the RF out and sometimes failing
  9. Naptown Muduck
    Naptown Muduck Light Load Member
    96
    78
    Jul 30, 2018
    are you sure your squelch didn't get turned up?
  10. mcarrara
    the squelch is fine
  11. mcarrara
    I brought it in and got it a tune up it was only pushing 4 amps bearcats normally push 15-24 I guess..mine is pretty old we got it to 18ish and called it good
