Because I was told, but never understood why?
Discussion in 'CB Radio Forum' started by TheDude1969, Mar 21, 2016.
  1. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Handlebar's post on coiling your coax is a perfect example, and got me thinking about some things I've always just done (or didn't do) because I read it somewhere, and never knew the purpose.
    Grounding:
    1. I fully understand the purpose of a good ground/counterpoise (at least I think I do), "to reflect the signal" in simplest terms. But if the coax outer braiding is already grounded and has 0 ohms to body, frame, and battery, what is the purpose of grounding (example a bird perch mount) to frame?
    2. Which begs the next question, why isn't the outer braiding used as the counterpoise... or is it? Thus making it a dipole, connected to a sea of grounded frame work, of chassis, body, and all kinds of hunks of metal within a vehicle.
    I've got many more questions, but don't want to muddy any response with other topics. Feel free to answer like I was in kindergarten, or draw a picture in crayon. <--- I find those most helpful!
  3. Ridgeline
    22,727
    123,499
    handlebar and TheDude1969 Thank this.
  4. TheDude1969
    807
    823
    Jun 10, 2013
    Joliet, Il
    CRAP ! I was wanting a one line post. J/K
    Thank you Ridgeline
    Blaskowitz Thanks this.
  5. Ridgeline
    22,727
    123,499
    Sorry next time I will just put up on line.
    TheDude1969 Thanks this.
  6. TheDude1969
    807
    823
    Jun 10, 2013
    Joliet, Il
    Antenna:
    I've been told, the thicker the antenna the more power/performance/distance and more broadband is a result. And I've read all the articles about top loading vs bottom, (I get it) but what I don't get is how the small guage conductor inside the coax can be improved by a thicker mass after its already been limited in size within the coax. <---thus a wattage limit within the coax?
  7. Ridgeline
    22,727
    123,499
    Not true.
    The distance/performance and so on are dependent on a lot of factors but it isn't the thickness of the antenna. The reason you see antennas being heavy is because they are put into a mobile application and need the strength to survive. The same goes for base antennas, they are made to survive wind.
    On top of that, there are a few uniquely designed antennas (like EH and CFA) that out preform any standard CB antenna that you can buy. These antenna are small, thin and in many cases fragile.
    I've used 24 gauge multi-strand wire before to talk to Europe with a couple watts, did a bunch of contacts to the Caribbean on 10 meters with a simple dipole and 100 watts. I just was reading this morning about a guy who uses digital modes and 100mws with a simple dipole on 40 meters by the way.
    Wattage is limited first by the transmission line - Coax - then by the antenna mechanical features. I've seen mounts melted by the heat with 5k but they were running hardline to the antenna. I don't think anyone should be running 5K in a mobile because of the amount of RF exposure, beside it really pisses people off for miles.
    I have three antennas setup at my radio location, the first is a dipole made of aluminium electric fence wire, the other is a vertical (like a big Stepper IR) and for now I have a 80 meter EH - all of these have had 1.5Kw through them at one or another time and survived, the EH got really hot but survived.
    Hope that answers some of your concerns.
    rabbiporkchop and TheDude1969 Thank this.
  8. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    A thicker Antenna add capacitance which requires a shorter coil for example a friend of mine used a piece of copper pipe on his F350 and it was only about 7 feet long but it was much thicker then a 9-foot whip
  9. Ridgeline
    22,727
    123,499
    But in many cases the diameter has to be increased a bit more than a 1/4 inch to actually see a gain. There is also a difference in using steel opposed to aluminium opposed to copper.
    TheDude1969 and rabbiporkchop Thank this.
