Belt alignment issue 96 w900l
Discussion in 'Kenworth Forum' started by sparky88, Dec 31, 2014.
  1. sparky88
    sparky88 Light Load Member
    143
    31
    Jan 22, 2014
    oswego, ny
    So my kW is squealing at 1500+ rpm. Open the hood and look from the passenger side and the belts are ####ed at an angle at the ac pump. It looks like the alternator got knocked out of alignment and seems that it's further forward then the ac pump. Any thoughts on how to adjust that?? The alternator has 3 different bolts on it. Also it's on a cat 3406e. Any help would be greatly appreciated
  3. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Sparky,if your pictures are accurate,then your AC pump is not aligned.
    in your first picture there is more space at the top then at the bottom off the pulley.
    I would start from the cranckshaft pulley at check the alignment from there to both the AC and the alternator.
  5. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    Yeah I thought ac at first but didn't know how that would get knocked out of alignment. I figured the alt maybe got knocked forward
  6. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    Also if I remember correctly looking from the drivers side the belt appears straight going down from the ac
  7. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Check both,use a plumber's lead.
    sparky88 Thanks this.
  8. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    Thanks! I didn't even think of that! Lol. The squeal has been going on for a couple weeks and I can't take it anymore
  9. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Chances are that something is cracked or broken. I went through the same thing. It was my A/C compressor mounting bracket. My engine is a Detroit. It wasn't obvious until my mechanic took some parts off and found it. My belts were jumping off.
  10. PurplePete
    PurplePete Light Load Member
    131
    24
    Nov 15, 2011
    Tyler, Mn
    AC or alt could be busted, bearings, brackets. Could be an idler if you have one.
  11. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    Ac is fine. Something is up with the alt. it looks like it's pushed forward a half inch or so
