Belt rubbing tensioner
Discussion in 'Freightliner Forum' started by drell1980, Apr 8, 2022.
  1. drell1980
    drell1980 Bobtail Member
    Belt riding on tensioner arm, installed new belt and tensioner with new water pump. Has anyone had this problem with a cummins 6.7 isb 2017 freightliner? Can hear belt squealing.
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,081
    Sep 24, 2019
    Raleigh, NC
    Don't recall how that one is setup, but on other trucks I've had the alternator wobble in it bracket enough to push the belt out of line.
    Something like that would be a good place to start. Some pulley should look a little off from the others in the line when viewed from the side.
    Rideandrepair Thanks this.
  4. Cattleman84
    Cattleman84 Road Train Member
    10,026
    71,598
    Nov 1, 2017
    The Sticks, Idaho
    Might have a bearing going out on a pulley or idler and it is causing the belt to ride funny.
  5. Inderjit
    Inderjit Heavy Load Member
    771
    737
    Sep 17, 2017
    You did get the belt routed properly?
    AModelCat Thanks this.
  6. AModelCat
    164,921
    Anybody put a straight edge across the pullies and verify their alignment?
  7. SmallPackage
    5,813
    18,627
    Dec 20, 2019
    Marion Texas
    I’ve seen idler and tensioner pulleys wear into a cone shape after many years of use. They well walk the belt off one way or another. Worst one i’d seen pushed the belt back towards the front gear housing causing it to slowly cut through a bolt head like a band saw blade. Seems to happen more often when the belts are able to attract a lot of dirt and they polish the smooth face of the tensioner pulleys.
