Belt Tension
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by johnnyboyloco2500, Jun 9, 2020.
  1. johnnyboyloco2500
    johnnyboyloco2500 Light Load Member
    67
    12
    Dec 7, 2015
    Lebanon,Oregon
    2013 pete 386, cummis isx. A/c. Stop blowing cold.pulled over and belt was off. Tension r was sees up
    So question is, to get the bolt off with a allen head socket. Should i heated up a little or just spray good with liquid wench?
    Thanks
  3. Goodysnap
    Goodysnap Road Train Member
    3,749
    9,120
    Jul 12, 2017
    Very common for siezing. I have had to replace the whole accesory bracket many times. Aluminium vs steel. Threads are in the bracket.
  4. johnnyboyloco2500
    67
    12
    Dec 7, 2015
    Lebanon,Oregon
    So the treads on tension bottom that bolts to bracket. Reluar counter clock to get bolt out of bracket ? How much were brackets ?
    Why couldn’t you drill all the way thru and put a thru bolt?
    Thanks
  5. Goodysnap
    3,749
    9,120
    Jul 12, 2017
    You may be able to save it with a heli-coil or a through bolt and nut. There is no access to tighten from the back side when its on the truck. I don't remember the bracket being terrible. Maybe a 3-400?
    The bolt is standard RH thread.
    pushbroom and BoxCarKidd Thank this.
  6. johnnyboyloco2500
    67
    12
    Dec 7, 2015
    Lebanon,Oregon
    Thank you for all you info . Big a big help.
    Goodysnap Thanks this.
