Bendix AD-IP Air dryer problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by giannid, Oct 19, 2017.
  1. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    Yes, unloader is built into the head. If it is faulty, you can just replace the head. Comes as a simple kit with new gasket and bolts.
    giannid Thanks this.
  3. giannid
    giannid Light Load Member
    100
    13
    Dec 6, 2015
    Well, after digging into things a little deeper today, I think I found the problem. The governor was loose from the compressor and was leaking pretty bad. Would of just replaced it since I had it off but nothing is open on saturday. Took it off and cleaned up the gasket surface and added a little RTV to seal things up. The gasket wasn't that bad so I figure rtv will be fine until I get a new governor. Seems to be working fine now.
    Heavyd Thanks this.
  4. Heavyd
    7,829
    6,280
    Feb 4, 2009
