Bent bumper on a 389
Discussion in 'Questions From New Drivers' started by Coffey, Dec 3, 2020.
  1. Coffey
    Coffey Heavy Load Member
    715
    1,746
    May 14, 2019
    I Accidentally bent the right side of my bumper this morning as I was backing in to a farm I was hoping someone could tell me ways to straight it back out to normal or how much it would cost an shop to do it thanks
  3. AModelCat
    164,647
    Unfortunately if its creased you'll never get it back looking decent. If its just a minor twist you might be able to hook a soft sling around it and gently pull it straight with a comealong. Just use some caution because things can go sideways pretty quick when you're putting tension on stuff.
    Tb0n3 and Coffey Thank this.
  4. Coffey
    715
    1,746
    May 14, 2019
    the top of it by the hood got jam into a crease but the front side is sticking out about 5 inches in front of the truck and still is Smooth
  5. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    Easiest way is to use a piece of wood and a helper. Put the wood between bumper and something solid and gentle with the clutch. If you don’t have a helper you can use a jack. Either way be careful,because if the wood slips out you can make a bigger mess.
    Coffey Thanks this.
  6. abyliks
    abyliks Road Train Member
    4,115
    9,688
    May 2, 2010
    ludlow MA
    Just a regular ~18” bumper is like $400, not the end of the world
  7. Coffey
    715
    1,746
    May 14, 2019
    That ain't to bad I already offer to buy the replacement if we can't get it straight
  8. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    I had one of mine bent pretty good and a nice crease. Took it off and to a heavy machine shop and they stuck it between 2 big steel blocks and used a 50 or so ton press. After a couple good presses the crease was pretty much gone
    Coffey and AModelCat Thank this.
  9. Tall Mike
    Tall Mike Road Train Member
    7,686
    36,817
    Aug 20, 2014
    New York State
    Depending on how bad its bent..
    A flat bed ratchet strap anchored to a solid sturdy object will pull it out, or...
    If you can get the correct angle a good fork lift operator can push it out with the forks. Unfortunately I've had to use both methods over the years.. Farm deliveries can be a bear I know.
    Coffey Thanks this.
  10. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Find a walmart and push against the building if folded out. If bent towaed the truck, get the truck near a big tree. Put a chain around the tree and a come along between tree and bumper and start winding. 5 minute fix
    Coffey Thanks this.
  11. SmallPackage
    5,781
    18,559
    Dec 20, 2019
    Marion Texas
    If you can’t push against something. Park 90 degree angle with steer tires turned in on bent side for clearance and use ratchet strap or comelog hooked to bumper and landing gear on trailer. Slow pulls with a block of wood and hammer taps on the crease area to help relax it back.
    Coffey and 650cat425 Thank this.
