Best Battery for Combo Starting/APU
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Smellfunny, Jan 11, 2019.
  1. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    Customer has 2017 Peterbilt truck with the Bolt Luxury Sleeper/kitchen. Has a APU unit but only four regular 900 CCA batteries. They are bad now and he wants to install new batteries. I was surprised it did not have 4 extra batteries for the sleeper/APU. What would be the best type battery to use?
  3. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    I used a Alliance Dual Purpose battery. ABP/AE7T31
  4. Heavyd
    Heavyd Road Train Member
    7,829
    6,280
    Feb 4, 2009
    I would go with 650 or 700 CCA for a longer reserve capacity. 900s are only good for quick fast starts, but not long slow cranks or aux loads.
    spsauerland and Smellfunny Thank this.
  5. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    The truck dose not need extra batteries. Change them out to the 950's it will be fine. The sleeper runs off of a generator. The inverter is only used for one outlet usually for the tv. Everything else is 120 off the generator.
    KB3MMX Thanks this.
  6. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    This truck basically has a complete house on it.
  7. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    The ones I went with were 730 CCA.
    KB3MMX and Heavyd Thank this.
  8. Sharky88
    715
    851
    Sep 25, 2013
    Exactly the batteries are only used for starting the motor or the generator. I see you went with the 730. That ok you will change them out in about 8 months
    KB3MMX Thanks this.
