Best Grit for Sandbalsting Frame Rails
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Hilltop Hustler, May 6, 2025.
  1. Hilltop Hustler
    Hilltop Hustler Light Load Member
    79
    52
    Apr 29, 2023
    West Virginia, USA
    1st up on the 378 resto project is dealing with surface rust and getting her good on the before doing anything else. What grit sand should I use? Is 80 grit good enough? I used it as a deck hand to get rid of rust while working the Lake Boats. Due to budgetary restraints its all they'd let us have it it worked very well, if not slowly. But I didn't know if anyone else had a second opinion? Also how many bags shoukd I get?
    Side tangent: Going back to my first big boy job where I was a deckhand Merchant Marine on the lakeboats. Basically doing the equivalent work of a US Navy Bo'sin's Mate. Fightin' rust!
    broke down plumber Thanks this.
  3. 201
    201 Road Train Member
    12,824
    26,405
    Apr 16, 2014
    high plains colorado
    Walnuts!
  4. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Join one of the many FB blasting groups. Members will come up with stuff I didn’t even know existed.
  5. 1034-CAT
    1034-CAT Bobtail Member
    24
    9
    May 22, 2025
    BLACK BEAUTY, Not the Ones you chase with a Whiskey!
    Hilltop Hustler Thanks this.
  6. '88K100
    '88K100 Road Train Member
    1,497
    3,643
    Aug 23, 2020
    There are various grits of Black Beauty.
    Medium grit could be used but you may need larger nozzle on your blasting gun.
    Keep in mind you have to sand the blasted prior to priming..Fine grit will knock down heavy rust and leave a smoother surface. You want to get a mirror finish on that frame?
    W923 Thanks this.
  7. Jabuol
    Jabuol Light Load Member
    72
    302
    May 17, 2025
    Emerald Triangle
    Walnut shells.
  8. W923
    W923 Road Train Member
    1,426
    4,421
    Feb 28, 2022
    We use black diamond by us mineral
    It’s crushed coal slag
    20-40 is not going to go through a nozzle small enough to be supported by an average shop compressor
    30-60 will work great
    The surface will be rough but nothing that epoxy primer and decent paint won’t take care of
    40-80 works great on sheet metal and aluminum but we find it hard to feed….it seems susceptible to bridging in the pot
    Also will be slow going on heavy rust or thick paint
    wore out and D.Tibbitt Thank this.
  9. 1034-CAT
    24
    9
    May 22, 2025
    What W923 said is good solid advice in detail.
