Best Mileage to Replace Engine Mounts on DD15?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Apr 28, 2020.
  1. PE_T
    PE_T Road Train Member
    750k miles? 1 million? So it’s common to hear about replacing the “rear” engine mounts, but not much about the mileage interval. What about the “front” engine mount? The front one I never hear about.
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Never knew of a set interval. If you take a look at them and the rubber mount looks cracked or protruding out then its probably time. Also depends on the quality of the material as to longevity.
    Rideandrepair and PE_T Thank this.
  4. Rideandrepair
    17,574
    56,926
    Aug 8, 2015
    I replaced mine with ATCO polyurethane, and again only 5 yrs. later with original type. First time they were 14 yrs old, way overdue. The polys were shot within 5 yrs. to my surprise. Soaked with oil, but still, very dissatisfied with poly type.If I had to guess, 7 yrs or 750k, definitely would benefit from new mounts.If not sooner. Get new bolts, makes reassembly, much smoother.
    stillwurkin and PE_T Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,774
    9,201
    Jul 12, 2017
    I replace rear engine mounts when doing a clutch. There right in your face and time well spent to change them while I'm in there vs having one fail and have to spend a whole day just changing one side instead of knocking them both out in a few hours.
    Depends on the application of course and if its beat to death hauling tanker round the city or is it styrofoam through the plains?
    Front can be done anytime and usually outlast rears anyhow.
    stillwurkin, PE_T and Rideandrepair Thank this.
