Best pre emissions engine for mpg
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Phantom307, May 20, 2021.
  1. DDguy
    DDguy Light Load Member
    157
    101
    Apr 21, 2020
    Ont. Canada
    What turbo and hp would you run with that setup ?
  3. Phantom307
    Phantom307 Light Load Member
    222
    210
    Jul 5, 2019
    Cheyenne
    I will be pulling light loads, usually mail.
  4. Phantom307
    222
    210
    Jul 5, 2019
    Cheyenne
    That is one sweet truck with that huge bunk
  5. AModelCat
    166,500
    Only Volvo I ever drove had the VED12. Felt pretty gutless. 7th direct with an empty 48' highboy I could barely hold a steady speed up a small hill. Engine brake was about as effective as holding your hand out the window.
  6. '88K100
    '88K100 Road Train Member
    1,507
    3,716
    Aug 23, 2020
    60 Series...
    jamespmack Thanks this.
  7. DDguy
    157
    101
    Apr 21, 2020
    Ont. Canada
    60 Series with a few little things done to it so it cruises well at 1350-1500rpm range will probly be your best bang for your buck PM me if you wish
    swaan Thanks this.
  8. harold6091
    harold6091 Light Load Member
    120
    135
    Dec 25, 2018
    ive had an 07 volvo with a d12. at first it used to give me 7.4 mpg until an injextor went out and swap from single to double tires. after that i never saw more than 6 mpg driving at 64mph 1450 rpm.
    now i currently have a fl century 12.7l. 500 hp tune with a k31 turbo
    i consistenly making 7.8 mpg driving 65 to 70
  9. sbaumann14
    sbaumann14 Road Train Member
    1,253
    1,470
    Sep 1, 2010
    Rhinelander, WI
    Currently….
    03 FLD series 60
    Borg Warner 702 turbo
    Full tilt manifold
    Donaldson pass thru muffler
    Ecm program set up at 550
    I run stepdeck. Can count on one hand loads last year over 30k. Most of my stuff is between 10-23k. No apu but have Espar set up on isolated battery. Consistent 7.3-7.6.
    my cruise is set at 64. Anything above that makes no sense or money to me. 1525 rpm on a straight 10 with 3.70 gears.
    Vampire and olddog_newtricks Thank this.
