Best replacement for 171702
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Oct 1, 2021.
  1. truckerbangin
    truckerbangin Light Load Member
    268
    45
    Jan 22, 2013
    What the best replacement turbo for a modified 12.7 that’s pushing a borgwarner 171702 beyond it limits.
  3. jamespmack
    216,478
    I do not have a answer for exact part number. But if your making that kind of power a 17702 is over speeding or coming apart. You need to get your tuner involved and talk and figure out exactly what fits your engine, work, terrain, driving habits, expectations.
    At that level advise or recommendations from a message board is not were I would be for info.
    Part numbers mean nothing at that level, might end up having one built and matched from numerous part numbers.
    Rideandrepair and Brettj3876 Thank this.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    What James said. A 78 & 80mm are the next sizes up if that helps you any.
  5. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Ever had it dynoed? How much power did your tuner tell you it should be putting out at the crank or to the ground? Without knowing that it's hard to say what you need but if I had to guess you could start with an 80mm cold side and 1.32 or 1.45 A/R and go from there. Exhaust turbines are easy to swap out and only run about 300 shipped so once you have the cold side you can play around with different A/Rs until you find the size that fits your operation best.
    Rideandrepair and Last Call Thank this.
  6. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    What are your EGT's on a long pull? Are you pushing over 50psi? I've heard the 171702 is out of its efficiency range once you get past mid 40s. I run the same turbo on a hot Mack and thinking about swapping to a 1.45 ar
    Also if you go to a 78 or 80 and still keep the 1.32 your egt will drop a bit. @ProfessionalNoticer I would do what he says and experiment with diff exh housings on a bigger turbo
  7. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    delete wrong thread
  8. truckerbangin
    268
    45
    Jan 22, 2013
    Yes I’m running about 44-50 psi depending on load and driving style.
    Rideandrepair Thanks this.
  9. Rideandrepair
    17,556
    56,878
    Aug 8, 2015
    I want to know more about the Modifications. Don’t have an answer. I do have a 12.7 though.
  10. jamespmack
    216,478
    There is no one cookie cutter option. You need to build for your application.
  11. truckerbangin
    268
    45
    Jan 22, 2013
    All my trucks are built and specked for the work and environment we live and work in.
