Best Used Cab Chassis for 25ft Box? 6000lbs load
Discussion in 'Experienced Truckers' Advice' started by Chotu, Nov 27, 2021.
  1. Chotu
    Chotu Bobtail Member
    I need to find the best cab chassis for adding a 25ft box that weighs 6000lbs.
    I need to be able to go down rough back roads with ruts and rocks. I also need to be able to travel across the country or to Alaska without worrying.
    Was looking at Isuzu NQR trucks, but I saw they blow through engines fast when driven on the highway all the time. Is that true??
    The shorter the length of the cab added to the 25ft box the better. For parking. That’s why I was looking at the NQR.
    thanks
  3. Ridgeline
    22,814
    125,519
    Get a class 8 truck, cascadia with a 60” sleeper should give you 10 feet bbc, which you can put a 25 foot box on it, this will meet the under 40 foot requirements in all states.
    it haul the weight and be dependable enough to travel where you need to go.
    An Isuzu will be a tiring drive and they don’t last.
  4. Chotu
    I’m non-CDL and the 25ft, 6000lbs box IS the sleeper.
    It’s a custom RV.
    I heard the same thing about the Isuzus.
  5. GreenPete359
    GreenPete359 Road Train Member
    2,276
    5,475
    Oct 21, 2017
    Driving my recliner
    If you’re building a custom rv then you won’t need a cdl regardless of truck size. Get yourself a class 7 vocational truck like a Peterbilt 537 or 548 with a beefed up suspension to give you extra ground clearance.
  6. Brandonpdx
    Brandonpdx Road Train Member
    4,716
    4,848
    Dec 27, 2007
    Elkhart, IN
    Older F-450 or 550 with the 7.3 and preferably the 6 speed manual transmission are pretty stout small trucks. Most of them were regular cab vocational/utility trucks that are readily available used for pretty cheap. Probably you'd want an 84" cab/axle frame length at least. I would slightly prefer the 450 because it had the very common and not hard to fix Dana 80 rear end where as the 550 had a bigger medium duty Dana axle that was $$$ to service and repair and had a tendency for the housing tubes to crack at the spring perches from being overloaded. A big dollar repair.
  7. MacLean
    MacLean Road Train Member
    1,384
    4,116
    Sep 12, 2017
    Or a bus. Busses can be gotten cheap and would likely have a better motor that the Isuzu.
