Best way through Arkansas going north
Discussion in 'Questions From New Drivers' started by CDL CPL, Sep 14, 2017.
  1. CDL CPL
    CDL CPL Light Load Member
    186
    63
    Aug 14, 2017
    Iowa
    We are in DeRidder LA (west LA) heading to Kansas City KS. Absolutely hate the roads in AR. Is there any easier way to go north through AR or any easier route? Gotta be in KS by 8am tomorrow morning. Any suggestions??
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    in Arkansas between Texarkana and I-40 is the worst part (US-71) but the alternate options aren't much better. You could do a lot worse [in Arkansas] than US-71
    Don't be tempted to try US-259/59 (Oklahoma) or US-271/69. They're doable, but you won't gain anything except beat your truck up more.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    You can try going to alexandra LA which is to your NE, your goal at Alexandra is US 71 bypass to US 167 north.
    Running through the woods you eventually end up south of little rock then work your way towards KC. Ugh not that good.
    Alexandra to shreveport on I 49 offers I 20 towards Dallas. Eat the three hours into dallas then north on 35. That positions you for KC.
    I-35 to KC is another 8 hours and change. If you aint rolling tonight like right now you might not make it KC by sunrise and 11 hours. Other roads offer a bit less than 11 hours to KC according to google maps but again in the ozarks system and tulsa etc you will be beating your truck. I think if you left right now at 6PM you are going to be around 1 hour prior to KC by 7 AM tomorrow morning and have to stop for your 10. Then no delivery on time right? Little Rock to KC requires a full day the other way.... You are already somewhat out of position.
    The Ozarks that STexan refers to is a barrier a pretty formidable one.
    Contact your dispatcher right now and get a new appt time. Or have a team waiting in some position to grab your load so that customer will be served.
  5. CDL CPL
    186
    63
    Aug 14, 2017
    Iowa
    We got til noon now to get to KC. We were just trying to bypass that dreaded 71 but looks like there is no way around it. Thanks for the suggestions.
  6. STexan
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Sometimes it can be easy, sometimes not. Just depends on the day/time you traverse it and your luck.
  7. kemosabi49
    10,985
    47,941
    Jan 13, 2013
    SW Arkansas
    I used to run between sw Arkansas and Joplin a lot. I could take 71 to Ft Smith and it took almost 4 hrs to get to the north side of Ft Smith where I picked up 540 north. But when running at night, I could run to Little Rock I30 to 430 the 40 west to the same start of 540 north and it was only 10 minutes longer. Course you have to be able to run the speed limit.
  8. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Buddy 71 is the easy north/south route.
    Try us63, us 65 167, 412, AR 7 is a doo'zee in northern AR.
    NavigatorWife and mhyn Thank this.
  9. scythe08
    scythe08 Road Train Member
    2,905
    3,829
    Mar 19, 2007
    Portland, Or
    I run 71 from Texarkana up past ft Smith all the time I'm a tanker, to boot. It's fine.
    Other than there is now a 57,000(fifty something) lbs weight rated bridge on 71, a few miles north of Ashdown. I honestly don't remember that sign ever being there before up until a couple months ago. I still run it and so do the log haulers and everyone else, buy it makes me nervous
  10. luckystar
    luckystar Light Load Member
    113
    143
    Aug 1, 2017
    Thats adding over 100 plus miles going around to Little Rock, I use to run 71 all the time from Texarcana i always thought the hard part of that trip was on 71 North of 40,from Alma but that was when it was all 2 lane now its easy 4 lane up there.
    x1Heavy Thanks this.
  11. x1Heavy
    34,016
    42,144
    Mar 5, 2016
    If it's anywhere near mcalester this time of year, it's 5 gallons bug fluid to cross that lake north of there. Clouds of skeeters live there.
    I don't do too much north south across there. It's a succession of valleys and mountain ridges, walls really that go to 900 feet above sea level in nothing at all. East and west is fine. But north and south? whoo...
    I taint minded it too much. It's either dallas or little rock, I chose dallas earlier this evening. Provided dispatch can buy more and later appt time for early afternoon.
    NavigatorWife Thanks this.
