Best way to prime c15 fuel system?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by TruckNorris, Jun 10, 2016.
  1. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    Theres a check valve between the secondary filter housing and line going to the head(allen screw behind the bleeder screw), but bingo about the rest.
  2. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    Here we go. The problem is bigger than I thought.
    You will have to pressurize the tank to get fuel up to the primary filter.
    Priming of the remaining system is still necessary after that. Do like suggested before.
    TruckNorris Thanks this.
  3. TruckNorris
    TruckNorris Light Load Member
    71
    20
    Apr 7, 2012
    Oshkosh, WI
    Thanks everyone for the help, got it fired up. Topped off both filters. Pulled the fuel line off the primary filter and pressurised the tank, once fuel started flowing out the line we hooked it back up. Pulled the bleeder screw out and pumped into fuel came out steady, put it back in and hit the key. Kicked around for a bit but evened out and took off. Running smoothly now and letting it warm up to check for leaks in the cooling system. Thanks again everyone.
  4. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    So the pressure regulator is at the secondary housing?
  5. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    No presure reg is in the primary filter on the engine. Secondary is the water seperator on the frame rail .
  6. lilillill
    5,642
    13,472
    Nov 7, 2007
    Don't you have the two confused? I have a 1r-0749 on the motor. My primary is a Davco on the frame rail.
  7. TruckNorris
    71
    20
    Apr 7, 2012
    Oshkosh, WI
    Your correct, fuel line runs from the tank to the separator on the frame, then to the pump, then the secondary filter on the motor.
    lilillill Thanks this.
  8. Lyle H
    Lyle H Road Train Member
    1,292
    2,947
    Apr 16, 2014
    I think the confusion may be in the definition of "primary " and "secondary".
    I think some define "primary" as the "main" filter which is on the engine block.
    Others, like me, define "primary" as the "first filter the fuel goes through".
    Therefore, using that definition, the "secondary" filter would be the one on the block.
  9. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Yes I define primary as the main filter the engine comes with .
    And secondary as the the filter the oem adds onto the frame rail .
  10. TruckNorris
    71
    20
    Apr 7, 2012
    Oshkosh, WI
    Yes, when you put it this way your correct. When I first purchased my truck I didn't have a water separator, there for the one on my frame was primary in both regards
