Best way to study for your Pre Trip test?
Discussion in 'Questions From New Drivers' started by Drea, Jan 11, 2019.
  1. Drea
    Drea Bobtail Member
    4
    Dec 29, 2018
    What's the best way to studie a pre trip ?
  3. Drea
    Drea Bobtail Member
    4
    Dec 29, 2018
    Pre trip whats the best way to studie a pre trip?
    cleanbyrd Thanks this.
  4. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    Go to a truck stop and watch how all yhe experienced drivers do it...
    Oh wait no one does one.
  5. Drea
    Drea Bobtail Member
    4
    Dec 29, 2018
    Lol
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,593
    Nov 23, 2012
    Yukon, OK
    Do a search on YouTube. There are quite a few good ones, especially those featuring DOT officers showing how they do an inspection.
  7. Chinatown
    Chinatown Road Train Member
    78,488
    188,298
    Aug 28, 2011
    Henderson, NV & Orient
    You learn pre-trip in CDL School.
    In the mean time, scroll to top of this page and click on "CDL Practice Tests" and start memorizing.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Walk around the truck one time. Touching everything bolted, welded, attached to or poured into it. Nothing on a big truck is just there.
    Repeat the walkaround with a formal list of things to check.
    Repeat.
    And repeat.
    Eventually after many repeats you have it in routine memory inside yourself. You start here and go around checking this, that, something, or other etc as you go.
    Lepton1 Thanks this.
  9. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    I would add this.
    DO IT THE SAME WAY EVERY TIME.
    Get into a pattern, and keep that pattern.
    My dispatcher has in the past complained that I always find something wrong with our trucks (when I have to drive one different than my normal rig).
    The boss has consistently backed me up by saying that it was because I did a pre-trip on those trucks and caught the anomalies, unlike the regular drivers who didn't do a pre-trip.
    I've almost always had to add Oil and Coolant to every single truck I've driven. Because the previous drivers didn't even bother to open the hood and look. On many occasions its been gallons of each. As well as gallons of washer fluid.
    But that was because I did my pre-trip and did it in the same way every time.
  10. Metallica88
    Metallica88 Medium Load Member
    500
    315
    Nov 27, 2017
    There is a video on YouTube. It's by the APEX CDL institute. It's about an hour long and I find that it's most informative video on pre trips that I found.
  11. BrandonCDLdriver
    BrandonCDLdriver Road Train Member
    1,191
    1,462
    Sep 1, 2017
    Kick the tires light the fires!
    Honestly, the DOT pretrip only makes sense if you slip seat. I do a thorough pre trip on my truck like one time and then I live in it for god knows how long. I don't need to keep checking the brakes over and over in a week. I know that I barely use them and they always check fine. I don't need to check the oil over and over again because I know it doesn't burn or leak any. So I'll check it when I have the hood up for cleaning or whatever. I don't need to check the washer fluid over and over again because I know on the last trip I didn't use any. I DO check tires on every trip because they can change from one trip to another. But fluid levels don't change unless they leak or are used. You can do an airbrake test but I can tell you in a heartbeat if a truck will pass or fail with the trailer that is attached. I do check trailers well because I pick up different ones all the time. But my tractor, no. I live in it. I know every noise it makes.
    If you slip seat. yea. But assigned trucks, nah.
