BIg Cam Cummins Power Upgrade
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ethan_Dewe, Mar 12, 2025.
  1. Ethan_Dewe
    Ethan_Dewe Bobtail Member
    Hi everyone, I am new to the big cam world and Cummins cpl system etc.
    I have a 1990 Kenworth K100E with a N14 Mechanical NTC-365 rated at 375hp.
    Purchased the truck last year and has been awesome transporting our digger around and carting gravel, have since put a gravel trailer behind the old girl and although she still pulls good it just doesn't quite have the steam with loaded truck + trailer.
    I am wanting to add a bit more power and take it out to the 400-420hp range if possible?
    CPL is 904
    Technical Engine Configuration # D093546BX02
    What is required to get this up to the 400-420hp range? Fuel pressure/Fuel Button, Timing, Are the cams different between engine configurations based on hp range? Any help would be greatly appreciated, not many old school Cummins techs or people of knowledge around where I am.
  3. 062
    062 Road Train Member
    6,329
    33,969
    Oct 20, 2013
  4. OLDSKOOLERnWV
    19,143
    289,461
    My first question would be, do you have a functional pyro….?
  5. OLDSKOOLERnWV
    19,143
    289,461
    Your CPL shows you have a aftercooler, no doubt a low flow engine as well, or has it been changed to high flow…?
  6. Ethan_Dewe
    @OLDSKOOLERnWV sorry i only just seen your reply. Yep it is still low flow, coolant temp normally sits between 80 - 90 degrees celsius, havnt had it go past 90 degrees yet.
    Have since inframed the engine and had injectors and injector pump rebuilt.
    Injector pump was recalibrated to 400hp and have also added the N14 HT60 turbo.
    Pyro functions (factory gauge reading in centigrade) temp sits around 200c and up to 300c max in a long pull.
    Am lookng to get a little more out of her now, thinking possibly try the dual fuel line and swap out the button 1 or 2 sizes - not sure what button is in it currently
