Big Problems Over Thinking and Oversteering
Discussion in 'Questions From New Drivers' started by Truck4Fun, Dec 26, 2013.
  1. Truck4Fun
    Truck4Fun Bobtail Member
    27
    14
    Oct 6, 2013
    Pasadena, Calif
    Ok, folks. Need help.
    It's the end of my 3rd week in private CDL driving school.
    Almost ashamed to admit that the only driving I'm doing is driving my instructor crazy.
    I'm overthinking and oversteering.
    Haven't been able to get past offset backing.
    They say "don't overthink".
    So I come to a point where I'm reversing, about to back into a lane of cones and If I don't think/overthink... Do I guess? Done that but I've guessed wrong and end up with jackknife.
    I only remember thinking... go right to see the rim... go left to move away from it.
    Also told, "go right to get close to the cone, left to move away from it."
    Part of my problem is that as I try to back into the cones, I'm not getting the angle right so to prevent hitting a cone I start oversteering to get it right.
    As far as oversteering goes... when I do it I think I'm just 'steering' until I end up with spaghetti arms trying to unravel the truck before it jackknifes or hits a cone. Countersteer fast right?
    Also told "you have to FEEL it". I'm a newbie. Right now, the only thing I'm feeling is frustrated.
    How do I practice 'feeling it?"
    Any suggestions on how I can stop overthinking?
    Bought a toy tractor and trailer and worked all night trying different angles. But it hasn't helped much.
    Downloaded a driving simulation game and doesn't seem to help either.
    Sorry about the long post.
    Any and all useful suggestions are greatly appreciated.
    Huge Thanks.
  3. Moon_beam
    Moon_beam Heavy Load Member
    888
    1,289
    Aug 29, 2012
    The problem that I had when I started was trying to decide which way I wanted to back of the trailer to go. I gave up on that and when I switched to deciding which way I wanted the nose of the trailer to go it was much easier. If the nose needs to go right, the turn the steering wheel to the right and back up. If nose needs to go left then turn the wheel left and back up.
    The other problem I had was thinking that you should not do a pull-up because the instructors made it sound like it was a sin but when one of the other students told me to do a pull-up to take the KINK out between the tractor/trailer it seemed to connect with me at that time.
    Dan.S, x1Heavy, Truck4Fun and 2 others Thank this.
  4. HotH2o
    HotH2o Road Train Member
    4,100
    4,868
    Sep 23, 2012
    What I do is draw an imaginary line from rear trailer axle into the hole. Never turn your steering wheel more than 1/4 to a 1/2 turn. What length of trailer are you using? A 53' trailer takes about 10' to react to your steering. If you have to use a pull up then make sure the wheels are straight. Pull straight forward. Don't try to go left or right when pulling forward. You're only going to make it tougher on yourself. If you're correcting a truck problem, pull up 5-8 feet. If you're correcting a trailer problem pull up 10-12 feet. Hope that helps.
    Dan.S, Keithdabarber, davetiow and 2 others Thank this.
  5. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Put your hand on the bottom of the wheel. The 6 position. If your hand is there left will be left and right will be right.
    Another tip would be to put a strip of white tape at the bottom of the wheel. If you do that you will always have a visual aid when it comes to which way the tail of the trailer is steering.
    Dan.S, x1Heavy, Chrisallen321 and 4 others Thank this.
  6. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Do they provide any videos demonstrating backing procedures? (wrong and correct) For some, it helps to observe from a distance as one backs. Note what the steering does, note what the front of the tractor does, and how the trailer reacts. Try and get to a point (as you're observing others) where you can tell early on if the driver is doing it well and will succeed, or is in an attempt that is going to fail or be done inefficiently. You will then begin to pick up on proper setup and the initial actions required. You'll begin to notice these initial actions don't need to be precise, but they do need to follow certain guidelines and basics, and the polishing can be done later in the backing maneuver.
    Go to youtube and search "truck backing tutorial" or similar and see what comes up. Maybe something there will strike a chord for you.
  7. jbatmick
    jbatmick Road Train Member
    2,200
    2,510
    Dec 1, 2009
    hastings, Fl
    The only way to learn to back is simply try to do it. Then do it again, and do it, and do it, and do it, and do it, and do it, and do it, and do it, and do it.
    Then take a break and do it, and do it, and do it again. Practice , practice, practice.
    It takes practice to learn, and practice to keep your skills up. Some drivers more so than others, but you have to practice until it clicks in your brain ( and it will click ).
    None of us were born with the ability to hit the dock every time, we all had to learn. Keep trying.
  8. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    When I was a CDL instructor I told students that kept turning the steering wheel too much was to put their left hand on the mirror bracket. That will help you steer less. I have been known to duct tape a students hand to the mirror bracket, believe it or not after it was all said and done they thanked me. Also never turn the steering wheel unless you know WHY you are going to turn it, for every action there is an equal reaction.
    Dan.S, x1Heavy, Keithdabarber and 4 others Thank this.
  9. 77smartin
    77smartin Road Train Member
    2,183
    3,024
    Apr 3, 2011
    I dunno.
    Don't turn the wheel so much...takes time to realize that a 1/4 turn of the wheel while MOVING can have big results. I like to help out other drivers when the are struggling and I always notice them turning the wheel to much and not moving...sorta like my kid playing in the car. You will get it in time.
    Dan.S, x1Heavy, davetiow and 1 other person Thank this.
  10. millsjl01
    millsjl01 Light Load Member
    298
    375
    Jan 24, 2012
    Driver seat/sleeper berth
    Thats hilarious...true, and hilarious.
    My instructor in school used to throw his hands up in air, roll his eyes and holler "don't be wrasslin with the sturin wheel" and walk away. It wasn't as insulting as it sounds, he just got tired of repeating himself..lol
    x1Heavy Thanks this.
  11. Mniesen89
    Mniesen89 Light Load Member
    187
    68
    Nov 18, 2013
    Florida
    Easily the best advice I had in school....doesn't work for everyone but it may for you.
    Keithdabarber and Truck4Fun Thank this.
