Binders and chains help me with sizes and which to use with which.
Discussion in 'Flatbed Trucking Forum' started by Jcc garcia trucking, Apr 17, 2021.
  1. Jcc garcia trucking
    Jcc garcia trucking Bobtail Member
    6
    Apr 17, 2021
    I have a rookie question I’m new to the binders deal with chains can I use a binder of 3/8-1/2 with a 70 grade chains of 5/16 can anyone help me on this
    cke Thanks this.
  3. staceydude
    staceydude Road Train Member
    1,151
    5,041
    Apr 3, 2020
    You would need 5/16 - 3/8. I have a few 3/8-1/2 and they are to big for 5/16 and you would be taking a huge risk. Safest thing to do is get proper binders.
  4. Jcc garcia trucking
    6
    Apr 17, 2021
    cke Thanks this.
  5. Jcc garcia trucking
    6
    Apr 17, 2021
    So what size binders do I get Nd chains do I get as well cuz I’m going tomorrow to go get them
    cke Thanks this.
  6. RustyRod
    RustyRod Light Load Member
    69
    104
    Feb 14, 2021
    It all depends on what you are going to be doing, how often and a few other things. I have 12 3/8 chains 6600 wll and 12 5/16 - 3/8 binders 7100 wll.
    blairandgretchen and cke Thank this.
  7. beastr123
    beastr123 Road Train Member
    2,955
    24,246
    Jan 2, 2014
    Moose Jaw SK CAN
    You need 5/16-3/8 binders (normally rated 5400lb)
    3/8-1/2 binders are overkill for any flatbed or stepdeck as 90percent of the tiedown points will be rated at less than 5500lbs
    If you will be pulling a lowbed then 5/16 chain should stay in your headache rack unless it is used to tie down a loose auxiliary piece of less than 5000lbs and a 2 inch ratchet strap will do as well.
    PoleCrusher and cke Thank this.
  8. 201
    201 Road Train Member
    12,822
    26,404
    Apr 16, 2014
    high plains colorado
    Not so much on binders ( the screw type are the best) an old timer told me, "if you line up all the links in the chain ( no kinks) it will never get slack", I tried it, and it works.
  9. Jcc garcia trucking
    6
    Apr 17, 2021
    I’m sorry for not been more detail on my post my setup is a f250 on a 28ft Gooseneck
  10. Espressolane
    18,753
    117,671
    You have an F-250 and a 28 foot gooseneck to move freight, or are you putting an F-250 on a gooseneck trailer to move it?
    cke Thanks this.
  11. Jcc garcia trucking
    6
    Apr 17, 2021
    I’m putting it to work the truck Nd trailer
