Blackmark on the DAC record
Discussion in 'Experienced Truckers' Advice' started by PhoenixOneNine, Jun 1, 2022.
  1. PhoenixOneNine
    PhoenixOneNine Bobtail Member
    45
    20
    Nov 19, 2014
    Ogden, UT
    So back in Jan 2019 I got let go from my current company because my dumb self thought using THC free CBD oil would help with my stress levels and I got a dirty UA for it. They rehired me 3 months later in April 2019 and I resumed work as usual. This failed drug test isn't being reported anywhere except my DAC record and it's stopping me from getting a different job which I sorely need right now. Is there anyway I can get this removed from the DAC by having my company stop reporting it? I'm trying to avoid bringing this up to my company because I don't want to get canned and be forced out of the industry because no one else will hire me.
    Thanks in advance for any help.
    tscottme Thanks this.
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    It's the company that reported that information to DAC. DAC keeps that information for 7 yrs. They are like a credit reporting agency. Everyone nowadays is keeping records (a lot for not for good purposes). It would have to be the company's to have DAC remove it(the problem is you did fail a drug test).
    The other option is to explain to the new company what happened & see what they say. It has been 3 yrs. They can say yea or nay but you won't know until you try. Find a company that doesn't use DAC but Everyone now wants to know who they are hiring (to much liability for not knowing). All the best with your journey.
  4. Eddiec
    Eddiec Road Train Member
    2,327
    3,584
    Feb 2, 2015
    If you failed a drug test, then you are also in the FMCSA drug clearinghouse protocol that all companies must use when hiring drivers.
    Drug and Alcohol Clearinghouse
  5. bad-luck
    bad-luck Road Train Member
    3,442
    6,349
    Nov 16, 2013
    Baltimore, Maryland
    @Moose1958 may have your answer
  6. Chinatown
    Chinatown Road Train Member
    77,896
    185,151
    Aug 28, 2011
    Henderson, NV & Orient
    PhoenixOneNine Thanks this.
  7. Moose1958
    Moose1958 Road Train Member
    15,298
    33,966
    Dec 17, 2010
    Williesburg, Virignia
    It's possible to get it removed, but it is also not very likely. It sucks, but the issue is 391.23(e)(1). I'm on record that forcing a driver to go through the SAP process for THC is stupid. Just tell the driver they are disqualified until they can test clean and there be NO record. But, I don't make the rules.
  8. motocross25
    motocross25 Road Train Member
    3,890
    11,964
    Sep 23, 2010
    Overland Park, KS
    I came here to say what @Eddiec mentioned, while DAC is an issue, I think Clearinghouse would be the bigger obstacle.
    tscottme and nredfor88 Thank this.
  9. Moose1958
    15,298
    33,966
    Dec 17, 2010
    I don't think a Jan 2019 positive is in the clearinghouse. This was why I did not mention it. YES, the clearinghouse is an issue in general because carriers are required to review it.
    buddyd157 and motocross25 Thank this.
  10. PhoenixOneNine
    45
    20
    Nov 19, 2014
    Ogden, UT
    Correct. I'm clean in the Clearing House. I also did the SAP program right away just to be told "You're obviously not an addict. You can go back to work." during the first session, but each company I've applied to has told me "Sorry. We have a zero tolerance policy."
    I should have been more clear and less dramatic: Nobody that I'm applying to will hire me. I'm sure I could go get a job with any big company that's not offering anything different than what I have, but I'm looking for something specific. Been doing OTR for 11 years and now I'm looking for something local to take care of mom since dad's passing last month. It's the local gigs that keep telling me to take a walk and that's why I'm interested in getting this removed. Sounds like it's not going to be easy, though. Thanks for all the replies so far.
    tscottme, Chinatown and nikmirbre Thank this.
  11. wis bang
    wis bang Road Train Member
    3,467
    4,122
    Jan 12, 2011
    Levittown, PA
    Non DAC and pre-clearinghouse; the FCMSA indemnified carriers from any 'problems' arrising from compliance with the FCMSA requirement to provide ALL of the following when inquiries are made by a prospective new employer for the past three years.
    -Accidents
    -A series of questions regarding the applicant's drug and alcohol testing history.
    -Any drug and alcohol violations that the carrier learned from it's own check of the applicant's previous employers.
    Once the period of employment is over 3 years, you did not need to report that information and had no legal protection from any lawyer thinking someone's rights were trampled.
    Carriers were required to keep records of drug and alcohol positive results for 5 years available for audit/review purposes.
    Anyone terminated for a positive test post SAP was 'kinda' stuck for 3 to 5 years before it stopped coming up on non DAC pre employer checks...
    longer if the last employer did report it to the current carrier which was the only way it would surface.
    Drivers terminated who were not helped 'in house' to do SAP and the required return to work random testing often wandered off and found work somewhere that did not check with out seeing a SAP and doing the testing.
    I had one post accident positive who did this for 2 years and found his 'dream job' only to have that employer check...His wife had a nasty screamfest over that one; She didn't know about the post accident positive for cocaine...
    The there was 'that guy' who tried another job for a week while on 'vacation' and pees dirty only to return to his old job with no consequenses.
    The drug and alcohol clearinghouse was created to stop those who were finding loopholes and OP may be in a grey area.
    gentleroger Thanks this.
