Block heater
Discussion in 'Ask An Owner Operator' started by Wespipes, Jan 18, 2020.
  1. Wespipes
    Wespipes Road Train Member
    1,037
    1,816
    Jul 14, 2019
    At what temp do yall plug your block heaters? Me? Anything below zero.
  3. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,196
    May 10, 2015
    Detroit, MI
    Below 20
    Wespipes Thanks this.
  4. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    I plug it in about 8 hours before departure below 30 degrees. No need to leave it on any longer than that unless you really wish to send the electric company about $.25-.40 an hour. Over a weekend that could be more than $10-15.
    Rideandrepair Thanks this.
  5. Wespipes
    1,037
    1,816
    Jul 14, 2019
    I plug mine into my apu
    Rideandrepair and Studebaker Hawk Thank this.
  6. Studebaker Hawk
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    Your APU is far more expensive than 120v power at the house. After you take into consideration the purchase, fuel, and maintenance costs. I have to use my APU also, anything beats a cold start. All in the cost of trucking.
    Rideandrepair, Ruthless and Wespipes Thank this.
  7. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    What do you guy's look for to make sure it's working?
  8. Wespipes
    1,037
    1,816
    Jul 14, 2019
    The coolant temp should go up after a couple of hours
    Rideandrepair and Final Drive Thank this.
  9. Studebaker Hawk
    3,018
    9,852
    Oct 18, 2010
    NW Indiana
    3 things. One, after a few minutes if you know where the element is located you can hear the coolant "boiling". 2nd. When I plug it in, I will unplug it again, if it is working it will usually spark a little at the plug.
    3rd. The extension cord near any connection usually is a little warmer than the surrounding air, or if it is in the snow, it gets warms and sometimes melts the surrounding snow. They pull 1500-1800 watts, which is a fair amount of power.
    One major thing to remember. NEVER start the truck when it is plugged in. You risk burning out the element because the moving coolant is not in full contact with the element and will burn it out quickly.
  10. The Biggest Dawg
    The Biggest Dawg Light Load Member
    177
    99
    Oct 16, 2019
    [Location Not Found]
    Can you explain how you calculated the cost? I think the math is wrong.
    NVM I see you used 1500-1800w I figured it is 600-1000w.
  11. Chris M.
    Chris M. Light Load Member
    123
    87
    May 27, 2010
    Tater State
    I can’t plug mine in where I park. If it’s gonna be cold cold night like sub temps, I run it on high idle. Now just for pure comfort, I run my bunk heater even when I’m not in it. Warm truck is very nice to get into when it’s cold.
