Blood pressure for DOT physical
Discussion in 'Questions From New Drivers' started by 23YearoldTrucker, Jan 31, 2016.
  1. 23YearoldTrucker
    23YearoldTrucker Light Load Member
    114
    21
    Jun 3, 2013
    Phoenix, AZ
    Next week I take my dot physical test. I checked my blood pressure today, and it was 147/79 is that to high for DOT? ? I'm concerned about this I don't wanna fail... Do it have to be under 130/80 or what?
  3. Moosetek13
    Moosetek13 Road Train Member
    15,005
    19,070
    Nov 1, 2010
    Burnsville, MN
    The 147 number is a problem. The lower number can be up to 90.
    Don't drink any coffee or have any booze for a couple days before you take the test.
    Don't add any extra salt from now on, and try to get low sodium foods.
    And try to be relaxed during the test.
  4. Moose1958
    Moose1958 Road Train Member
    15,300
    33,975
    Dec 17, 2010
    Williesburg, Virignia
    That reading would get you a 1 year card and major trouble after the 1 year is over. Before the FMCSA mandated the medical database it was not an issue, but today it is. Honestly if you want to continue to drive Interstate you MUST get that BP down either with diet or medication.
    LGarrison Thanks this.
  5. 23YearoldTrucker
    114
    21
    Jun 3, 2013
    Phoenix, AZ
    I'm skinny I'm only 180 at 6'6".. but yes I need to exercise more.
  6. Diesel Dave
    9,767
    33,673
    Jan 20, 2010
    Hesperia, Ca.
    Lay off all salt and sodium(carbonated drinks). Drink alot of water and go walking everyday/exercise. I been there, I know what it takes. Also, get plenty of rest all week. You should be okay by D day.
    jasin1487 Thanks this.
  7. Moose1958
    15,300
    33,975
    Dec 17, 2010
    Also this is one area I agree 100% with the FMCSA. High blood pressure is a killer. The feds are doing all truck drivers a big favor here. It is not just your job, it is your life!
    jasin1487 and Tonythetruckerdude Thank this.
  8. TigerShark
    TigerShark Medium Load Member
    454
    329
    Nov 5, 2015
    When they take your blood pressure.
    Hold your breath count to 100, and watch them panic. :)
    tucker Thanks this.
  9. mnmover
    mnmover Road Train Member
    1,237
    1,104
    Apr 5, 2009
    Lichfield MN
    And your reading was on what kind of machine? The home version machines are somewhat accurate, but are so you can tell if the pressure changes so then to see the doc. The easiest way is to take a Viagra the day before. Also sit and relax before they take it for 5 minutes or so.
  10. Chewbongka
    Chewbongka Light Load Member
    169
    130
    Feb 11, 2015
    Ask them to take your BP manually. The automated machines tend to read higher compared to a using a hand pump cuff and using a stethoscope. Also make sure the cuff they use is the correct size, if it's to small in width it will give off a higher reading.
