Blower not working
Discussion in 'Volvo Forum' started by Gedas429, Apr 7, 2015.
  1. Gedas429
    Gedas429 Bobtail Member
    7
    Mar 23, 2015
    Hello, my 06 volvo vnl front blower topper working. Could it be the motor or speed controlling switch?
    Also how can I check either one? And how hard is it to replace the blower motor?
    Thank you
  3. WitchingHour
    WitchingHour Road Train Member
    3,422
    2,142
    Apr 1, 2011
    Broomfield, CO
    Could be either one.
    Start with the simple stuff first... check your fuses and relays.
    The switch, you remove it, determine which input is for power, which is for ground, then you run a continuity test with a digital multimeter.
    The blower motor... expose it and unplug it. You can take a test light or Power Probe and verify that you have power going to the blower motor... to verify that your ground is intact, you'd want to use something like a Power Probe or "logic tester" style of test light. If you don't have power, and your fuses and relays checked out, and your switch checked out, then it's a matter of tracing wires. If you do have power, then you supply power to the blower motor itself (because, even though you have power, you might have insufficient current at the intended source, still), and if it doesn't respond, you know your blower's bad.
    As for how to access it on the Volvo, I'll leave that to someone in the know... I could tell you how if it was a KW, but I've never had to do this on a Volvo.
  4. Gedas429
    7
    Mar 23, 2015
    Thank you for the response! I will try all those things thanks again
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,640
    Oct 11, 2010
    Borispol, Ukraine
    Blower is PWM controlled from Climat Unit. There is motor PWM driver, it is mounted on C-shaped radiator, speed is controlled with n-channes MOSFET, try to solder in new one
  6. mrtrdrvr
    mrtrdrvr Light Load Member
    154
    35
    Nov 6, 2009
    Indian River ,MI
    To get to the blower on a 2nd gen volvo remove the right dashboard panel. You'll need to remove the grab handle first and one of the dash panel mounting bolts is under the right hand speaker cover. Once the panel is off you'll be looking at a black plastic box for lack of a better word. Your fan is inside that box at the bottom. Remove a bunch of those little metal clips with a small prying tool being careful not to distort them because you'll reuse them to put it back together. Drop the bottom part off and the blower IIRC will slide out.
  7. RubyEagle
    RubyEagle Medium Load Member
    631
    777
    Apr 17, 2010
  8. Jooeugen
    Jooeugen Bobtail Member
    28
    Mar 14, 2021
