Blowing white smoke after long idle
Discussion in 'Freightliner Forum' started by DimengionX, Oct 11, 2020.
  1. DimengionX
    DimengionX Bobtail Member
    7
    Oct 11, 2020
    2019 Freightliner Cascadia Evo
    228,000 miles
    Problem: After long idle/opti idle white smoke blows in through ventilation system and out through hood vents when coming to a stop. It will persist for about 10-15 minutes then not happen again until after another long idle.
    I’ve tried stopping and inspecting under the hood during this time and cannot pinpoint an origin. Smells like oil or when the truck is in the process of a regen. The engine will sound groggy but then normalize after smoke clears. I’m assuming it’s burning off excess fuel or oil accumulation during a long idle but I cannot pinpoint the origin or what is causing the buildup.
    Outside of this, the truck runs perfectly. This only occurs after a long idle and I take off for the day. Any ideas on what the problem is?
    Possibilities: Bad injectors, timing off, gadgets, bad turbo seals?
    Note: No alerts or fault codes are popping.
  3. DUNE-T
    DUNE-T Road Train Member
    7,058
    17,201
    May 10, 2015
    Detroit, MI
    I was fighting the same thing recently with my Cummins engine, changed injectors, ecm, harness, all that stuff. Eventually engine got destroyed, but I think timing might have been messed up, because I was also constantly changing cam sensors
  4. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,459
    6,869
    Oct 22, 2016
    North Dakota, Eh?
    Check flex pipe behind turbo. We occasionally have one go bad.
  5. DimengionX
    7
    Oct 11, 2020
    Thank you, I’ll take a look at it and let you know.
  6. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Doesn't that mean a new Pope was picked?
    otterinthewater Thanks this.
  7. DimengionX
    7
    Oct 11, 2020
    So it turns out it was the bellows/flex pipe that was cracked. Found carbon tracking all along the pipe.
    Dt12 and Muddydog79 Thank this.
  8. engine947
    engine947 Bobtail Member
    Did you by chance take pictures of the back part of the pipe. Thanks
  9. Ent1911
    Ent1911 Bobtail Member
    4
    Dec 12, 2024
    Had long fight with the white smoke, for me turned out to be intake gasket, so il ill advive check that out plus please share uf it helps
