Blown Air Bag Question
Discussion in 'Experienced Truckers' Advice' started by MercySakesAlive, Mar 12, 2026.
  1. MercySakesAlive
    MercySakesAlive Light Load Member
    132
    74
    Aug 8, 2008
    seattle ,wa
    I gently backed my fully loaded (75k gross) trailer tires up on a curb in order to maneuver out of a loading area. Then i noticed my air bag was blown. Did I cause the air bag to blow by rolling up on the curb?
  3. 201
    201 Road Train Member
    12,798
    26,342
    Apr 16, 2014
    high plains colorado
    I don't think so, air bags wear just like anything else, I'd check to make sure nothing was rubbing on the air bag itself, it's an easy fix. You may have to tie off the air line going to it, as you'll never build up enough air with it blown.
    tscottme, MercySakesAlive and ESAFO Thank this.
  4. LTLTRUCKDRIVER
    LTLTRUCKDRIVER Light Load Member
    189
    351
    Jun 3, 2019
    I would check the other bags for dry rot, wear, and cracks. Might need to change others before they blow.
    Bean Jr., tscottme, Oldman83 and 2 others Thank this.
  5. MercySakesAlive
    132
    74
    Aug 8, 2008
    seattle ,wa
  6. Arctic_fox
    4,532
    25,648
    Sep 16, 2016
    Could have been a rotted bag and the curb made it fail sure. But bags are a wear part and get especially beat up in winter. Salt, weather, road slime, small rocks, bugs, and anything else that may be encountered on a road can hit them and chew them up over time. And they can just blow at random or flex and open up along a wear seam.
    General rule i was always taught is 5 years or 150k miles you change them regardless of if they need it. 100k miles if your always loaded heavy and haul in places with abrasive materials like lava dust or chemicals a lot as it can cause premature wear. You can go longer obviously often much longer. But at 150k you generally head off issues and bags are cheap. Easy to replace yourself if your handy with a wrench.
  7. FLHT
    FLHT Road Train Member
    1,432
    2,546
    Aug 2, 2014
    My parts house quit stocking Firestone bags.
    They claim to many quality issues...
    HoundDog7 Thanks this.
  8. panty snacher
    panty snacher Light Load Member
    83
    90
    Oct 11, 2025
    did the bag actually blow apart or did it just come apart bag from the the plastic mounts on each end..If the air bag came apart .I did it on a 379 the truck and trailer was parked at a very strange angle and down a hill while loading .Since you stated a out of the ordinary angle about a curb I would assume that it actually just came apart so you might have not been able to help the situation but probably what caused it.I don’t really know if letting the air out of the bags while at a strange angle until loaded then move up to level ground would help never talk to any one about that.
  9. HoundDog7
    HoundDog7 Light Load Member
    216
    1,108
    Oct 7, 2022
    Kansas
    The Firestone air bags for the air ride on my cab straight from Kenworth have lasted an average of about 2 years before they seem to dry rot out. I can agree from experience that Firestone is definitely having issues with airbags. On my 3rd and final set
  10. 201
    12,798
    26,342
    Apr 16, 2014
    It's the cheap $#!+ Chinese rubber they are probably using. I remember years ago, we rarely had an air bag blow out.
  11. KDHCryo
    KDHCryo Medium Load Member
    642
    993
    Sep 14, 2023
    I run Contitech's on my Freightliner, and they've been pretty good for the last 250K miles. I'm tanker and always heavy.
    I carry an Amazon chinese knockoff under the bunk as a spare in case one blows, so's I can get to a more suitable location to replace it with another Contitech.
    Edit to add...it's cheap insurance to get an old spray botlle and mix up 75/25 water to dishwashing soap and spray down your air lines and bags and chassis. Anything that has air in it, especially if you notice your air compressor coming on more often. it's cheap and that spray bottle will show you a rotten bag before it fully blows.
    You've got nothing better to do on your 34 anyways, lol.
