Blown turbo
Discussion in 'Peterbilt Forum' started by Liles, Nov 5, 2016.
  1. Liles
    Liles Bobtail Member
    I blew my turbo and I'm wondering if there's any way to clean out the air to air or if your just ahead to buy a new one. Thanks.
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Any major dealer will "rebuild" the cooler. Clean it out, pressurize and fix leaks, and normally repainted black(at least what our shop used to get back from freightliner). Much cheaper than buying new as long as you pull it off yourself and take it to them. In all truth, a radiator shop would likely be able to perform the same service if no dealers are nearby.
  4. wore out
    wore out Numbered Classic
    17,426
    216,887
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Be sure to clean the fresh air side too. I have seen them blow debris back to the air filters then when they are started it goes right thru a brand new turbo. Sure makes a guys lip pooch out when it happens.
    cumminskid123 and BoxCarKidd Thank this.
  5. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    Remove it and flush it out real good with soapy water or degreaser. Took a bottle of dawn and a half bottle of degreaser before I was satisfied with mine...of course the wife wasn't thrilled the next time she went to wash the dishes and her dish soap was gone...but I got my truck back together and that's all I was concerned about at the time.
  6. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    Pffft, just run it through the dishwasher next time....
  7. passingthru69
    Clean out your air breather tube and buy new air filter also
  8. Pedigreed Bulldog
    7,737
    14,424
    May 7, 2011
    Yup. I pulled everything from the air cleaner through to the intake manifold off the truck to clean thoroughly. New air filter. Change the oil. New turbo. Good to go.
  9. bzinger
    bzinger Road Train Member
    16,659
    66,216
    Dec 10, 2014
    omaha , ne
    Yep had my charge cooler sent to a radiator shop in Boise Idaho they cleaned , tested and repaired it ...was cheap too.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,555
    6,643
    Aug 26, 2014
    I have done a few of those. Some were mine but most were not. The worst was a Mack that was towed in to a
    satellite terminal.
    Asked if you want me to take the CAC to a radiator shop and have it flushed out. Take it off and back flush it out with a pressure washer as best I can or replace it.
    No don't worry about it. Just put the turbo we are sending you on it and it will be fine.
    Started it up and it ran away. Pulled the engine stop cable out of the dash and my hand slammed window on back of the cab. Could not get it in gear or break the gear shift lever off. The only one I ever left. It rolled smoke like the best tractor puller. The valves would float and slow it down and go again for a few cycles, maybe three minutes and it shut off. Checked fluid levels, moved stop lever on pump, put it in high gear and started it up. Ran perfect but could here the rods knocking when the throttle was let off.
    In hind sight I probably could have saved it by dumping the fire extinguisher in the air filter.
  11. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    This sounds like a pretty exciting experience lol, thanks for sharing man
    thejackal Thanks this.
