bought a truck - guidance/progress
Discussion in 'Trucks [ Eighteen Wheelers ]' started by INF3RNAL, Sep 12, 2010.
  1. INF3RNAL
    INF3RNAL Light Load Member
    159
    76
    Aug 28, 2010
    Gurnee, IL
    Ok, here's the deal. I found a truck I liked and paid cash for it. Hoping to use it for work around the house so I can be home a bit more often and hopefully make the same paycheck. That's all neither here nor there, I suppose, though, as this thread will be used for me to ask questions and post updates of my progress as I do things to the truck.
    First, some info on the truck:
    1995 International 9300
    N14 Cummins 500HP
    13spd, 3.55 rears, 24.5 tires
    I'm out on the road right now, but first order of business when I get home is to apply some POR15 to the rear frame. It's not terribly rusted, but the paint is clearly gone and surface rust is present. If anyone here has tips on using POR15, I'm all ears.
    Now for the questions.
    Locking fuel caps: yes or no? I've had fuel stolen out of this company truck once, and I can't imagine I'd be very happy if I was the one footing the bill. Does anybody here use them?
    I'm mechanically inclined, but don't know a whole lot about trucks. I've been reading the pages of information on this board and taking in what I can, but I'm sure there is plenty more to be had. Where can I go for a general reference on truck maintenance/repair? I know I should be constantly greasing the truck(weekly it seems for some parts) but I don't know what all should be greased, and what grease I should use. If anyone can recommend a good grease gun as well, please share.
    What would be the first things you guys would do to a truck you just purchased?
    Basically I'm looking for any advice I can get, whether it be maintenance tips, knowledge of this engine/truck, or pretty much anything to keep me going. Thanks.
  3. canuck in da truck
    canuck in da truck Road Train Member
    4,352
    2,601
    Aug 6, 2010
    western pa
    as for the por 15--scrape off the heavy stuff--then if you can spray it on its better--it goes on nice--but it does need to be painted over as well or the ultraviolet will detiorate it--just use something like rustoleum to cover it
    you can get the anti syphons for your tank as well--then dont need new caps
    at minimum i would grease the ujoints and spring pins every week---and rest every two weeks---lincoln guns are pretty good--buy an extra hose so you can double the length of hose--makes it a bit easier--maybe good idea to replace air filter and date it--
    i would check all fluid levels--diffs tranny---pull bottom plug and check for excess material as well---if you know its full--you dont have to check it again unless you see leakage---give everything a good going over--make alist of whats worn -but livable so you can replace/fix it as time and money allow
    ih is a pretty decent truck-- never found them to be to problematic
    INF3RNAL Thanks this.
  4. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    Keep one hand gun loaded with high temperature grease for the throw-out bearing. Look for the zerk hanging down from the bell housing.
    Begin replacing old flexible air hoses. Take a few at a time to a place that makes new hoses. You may be able to park in their lot and walk your old hoses into the store. In an hour or so, you can be on your way with no worries about the hoses you replaced.
    INF3RNAL and 25(2)+2 Thank this.
  5. INF3RNAL
    159
    76
    Aug 28, 2010
    Gurnee, IL
    What grease do you guys recommend? Right now looking at Mystik... Do I need grease with EP additives for general use or only for certain parts?
    This stuff seems about right, yes?
  6. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    I always use the good hi temp napa brand grease or somthing similar, as much as you use, why spend $30 a tube when you can spend $4? just my opinion and have had good luck with napa stuff.
  7. INF3RNAL
    159
    76
    Aug 28, 2010
    Gurnee, IL
    I think that's 30 for ten tubes.
    country29 Thanks this.
  8. country29
    518
    157
    Feb 27, 2010
    ok, then that is a good deal, i didn't look close enough at the description. I always grease everything every 2 weeks, but thats me and how I do it, some will say thats too often, some say not enough.
  9. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,483
    Oct 18, 2009
    Waynesburg, Pa
    I have had trouble with the lincoln guns. I took the first 1 back the 2nd was no better. Bought a Lucas at Home Depot works very well. Extra long hose or 2 put together is a great idea. I get the heavy duty Lucas grease as well. The redntacky grease is not high temp and turns to liquid very easy. I dont think its very well suited for trucks
    canuck in da truck Thanks this.
  10. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    The first thing I'd do is get the strongest degreaser you can get and clean it from top to bottom. Concentrate on the undercarraige. Then go under it with the brightest trouble light you can find. Make notes of any loose wires or broken clamps for hoses air lines etc. On a 95 truck there is bound to be some of those. Fix them. It won't be expensive just time consuming. Clean the axle housings,trans and engine until they're clean so you can discover and fix leaks. I wouldn't even worry about greasing it until you have a good idea of the overall shape of the unit. Make sure the frame crossmembers are tight (look for red dust under bolt heads) Check u-joints for up and down play and twisting play. A little up and down (1/16") is ok but will need to be fixed soon. Twisting play needs to fixed before pulling a load. Check for up and play on the output shaft of the trans and the input/output shafts of the rear ends. They should be able to rotate a bit but not 1/2 a turn. Up and down should be minimal and look for bad oil leaks there. A little seepage is ok but it shouldn't be leaving a puddle. Again its not a hard expensive job just a dirty time consuming one to change seals. My maintenance schedule is grease and level check every 30 days(6,000 miles) Some say thats not enough but I'm on my original kingpins and have only replaced two u-joints in 800,000 miles and 11 years of pulling heavy (135,000lbs). Good luck with your truck.
  11. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    lots of good advice here, here's a few off my suggestions:
    1.climb all over the truck before you degrease it, this will show you leaks and problem areas
    2. clean the truck top to bottom as best you can.
    3. grease is the cheapest and best insurance you can buy. regular greasing is more important than the type.
    4. fix all wiring with non insulated splices and heat shrink . cheapest and best way.
    5. buy spare belts and filters.
    6. buy spare fuses, some trucks take both the large and small push in type. do you have any glass fuses/ inline/whatever you call them?
    7. test strip the antifreeze.
    8.seriously inspect the battery cables and the connections.
    9.do you have air tools and a compressor? plan on getting one.
    10. don't give up.
    johnny
    uptownkid and INF3RNAL Thank this.
