BP control w/ meds? Is it OK?
Discussion in 'Driver Health' started by Rowdy Finn, Jan 6, 2011.
  1. Rowdy Finn
    Rowdy Finn Bobtail Member
    44
    4
    Oct 7, 2010
    Eastern NC
    I'm 55 yrs. old and going to orientation in 2-3 wks. 1st job after school. My family has a history of hypertension. I did a 132/80 for med. card for CDL. Went to th doc for an earache the other day and did a 141/94. I think I'm borderline just depends on the day. Should I seek help from a doc and possible meds. to lower BP before traveling all the way to orientation? Will taking a pill for BP control cause trouble at orientation physical? Just don't want to be sent away. I need to start working again and this is a pretty good starting company. Thanks in advance for any sage words of advice.
    JustSonny Thanks this.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It's a good idea to get on Lisinopril 10 mg. I was like you, border line. Now I'm 128/75. Like a trained athelete :)
    The next physical they might limit you to yearly physicals to keep a closer eye. But your body would be better off with the lower BP.
  4. xlsdraw
    xlsdraw Road Train Member
    4,241
    9,047
    Nov 17, 2010
    Lake Alfred, Florida
    I'm lucky. 5mg of Lisinipril does the trick for me!
  5. wildbill123
    wildbill123 Heavy Load Member
    713
    322
    Jan 31, 2009
    SE,MI
    5mg of Lisinopril used to do it for me, now I'm on 10mg and my BP stays around 120/75.
    I would go to the doc and have him prescribe something before going to orientation. If you blip over 140/90 they might send you home.
  6. Rowdy Finn
    44
    4
    Oct 7, 2010
    Eastern NC
    Thanks for the responses. Guess I'll have to ask about that stuff. Any side effects? Can you stop taking it after losing a little weight and if the BP stays down low enough?
  7. Flying Finn
    Flying Finn Heavy Load Member
    972
    558
    Jun 22, 2010
    Ontario, Canada
    Has the Doc been able to diagnose WHY your BP is going high? That is the critical question. There may be an unknown underlying cause sitting like a time bomb.
  8. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    No side effects for me except for a tingling throat sometimes. I blame it on the cigarettes and my doctor said that's a side effect of Lisinopril?
    The key is regular BP monitoring. Weight has an effect on BP, so does a family history of hypertension. Narrowing arteries or even partially clogged arteries can raise your BP. Maybe it's time for an EKG too.
    When you start trucking, you'll have a hard time losing weight. Healthy food access is slim unless you bring it with you. Try to stay ahead of the game. Many fall into the trap of fast food, twinkees and lack of excercise. When you work all hours of the changing clock, many days you will be too tired to do anything.
  9. Lilbit
    Lilbit Road Train Member
    16,583
    12,233
    Aug 4, 2008
    Let me check my logbook
    Being sick can mess with your blood pressure as well!
  10. Bumpy
    Bumpy Road Train Member
    6,536
    5,265
    Jan 27, 2009
    New Ulm,MN
    I would go to orientation with BP dope,better to have it controlled that way than have a high reading.,my lisinopril is 40mg,-is that right?-yup,but anyway,I am 99% positive if on any of that stuff,the card will only be good for a year,in fact,if you wanna look it up after I thought about it,it is in the little pocket rulebook you are sure to receive in orientation..
  11. chopper103in
    chopper103in Road Train Member
    2,407
    6,562
    Apr 11, 2010
    Crossville,Tn
    i myself am on lisinopril for high bp. when i first started taking it it seemed that i would get sleepy after i took it when i got up, so i switched to taking it at bed time
    i have been taking it for over 20 years now and my bp stays in good shape as long as i take my meds
