brake adjustment
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by ralin10, Jul 27, 2014.
  1. ralin10
    ralin10 Bobtail Member
    41
    4
    Apr 24, 2014
    Hello, can someone tell me how to adjust brakes on a Peterbilt 2005 378 model.
  3. Powder Joints
    8,041
    8,508
    Sep 25, 2007
    Rosamond, SoCal
    General, Snug the adjustment to bring the shoes to the drum, then back of between 1/2 to 3/4 of a turn.
    Exact directions depend on what adjuster are on that peticular tractor or trailers, ther are many different designs so check with the shop guys at your company.
    ralin10 Thanks this.
  4. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    if it has the same hardware as a T660, take a 10mm socket and ratchet, find all six slack adjusters and rotate the adjustment screw clockwise until the it stops, then rotate counter clockwise 1/4 or 1/2 of a turn.. you should hear a clicking noise as you back them off.. and you can only do this while the brakes are RELEASED.. so make sure you chaulk your tires or pull the red valve to park the trailer and leave the yellow valve pushed in to keep the truck brakes release.
  5. Pedigreed Bulldog
    7,737
    14,425
    May 7, 2011
    A 2005 SHOULD have auto-adjusting slack adjusters on it. If they require manual adjustment other than immediately following other brake work (new shoes, etc), then they should be replaced. Frequent manual adjustment of certain types of auto-slacks will cause them to wear out.
    SLANT6, ralin10, Hammer166 and 2 others Thank this.
  6. Gordon A
    Gordon A Medium Load Member
    384
    345
    Jul 22, 2013
    Here is the easiest way to adjust brakes. Park or at a light. Press brake pedal down to about 100 - 120 psi or just hard. Hold for about 5 seconds. You may hear them setting up or just one. It is usually the steer you hear. this is done with out setting any of them. Next time you use them you will feel an improvement. I do this at end of ramps and traffic lights and if pulled around at a scale. Never been cited for out of adjustment brakes by doing that .
  7. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    If they are auto this is the best and only way to be safe.
  8. flybynight1
    flybynight1 Light Load Member
    62
    24
    Jun 23, 2014
    correct me if im wrong but i thought i heard drivers couldnt adjust there slack adusters for the fact of safety and that a trained mechanic had to do it
  9. Alaska76
    Alaska76 Road Train Member
    1,228
    1,653
    Jan 20, 2014
    Inland Empire, WA
    I believe that if "you, the driver" hold an Air Brake certification, that would be incorrect?
    AndrewH Thanks this.
  10. Gordon A
    384
    345
    Jul 22, 2013
    If the brakes need to be adjusted use the foot valve like posted earlier.. Manually adjusting means they need to be replaced. New slack adjusters are not to be manually adjusted like the older ones could be. The decal on them states that they are not to be adjusted.. Older equipment is ok to adjust by hand.
    jeffo51 and ralin10 Thank this.
  11. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I agree with Gordon . If you need to adjust a auto slack adjuster you may be covering up other problems such as worn s cam bushings constant adjustment breaks prongs off inside of adjusters then makes them useless .. If you have to back off a brakes some have a pin you lift with a sceewdriver to prevent damaging internal mechanism
    Gordon A Thanks this.
