Brake chamber air line
Discussion in 'Ask An Owner Operator' started by Keepforgettingmypassword, Jun 21, 2022.
  1. Keepforgettingmypassword
    Keepforgettingmypassword Heavy Load Member
    738
    938
    Jan 11, 2022
    After I drain the air. Is it as easy to change as it looks?
  3. jlafume
    jlafume Light Load Member
    241
    324
    Jan 6, 2011
    Victorville,Ca
    I would put the cage bolt in, after that its easy 2 change
  4. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Sorry this was a vauge question. I am only trying to change the air line. Does it still require the cage bolt?
    If so I will watch some one do it the first time.
    OLDSKOOLERnWV Thanks this.
  5. FozzyNOK
    FozzyNOK Road Train Member
    2,482
    3,826
    Jul 18, 2007
    Oklahomistan
    As long as you're not cracking the chamber open, You should be OK.. There isn't any air in them unless you charge (release) the brakes
  6. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    Thank guys. I was nervous. I m gonna do it tommrow or Thursday let's see what happens.
    Rideandrepair and OLDSKOOLERnWV Thank this.
  7. FLHT
    FLHT Road Train Member
    1,439
    2,586
    Aug 2, 2014
    No cage bolt required...
  8. abyliks
    abyliks Road Train Member
    4,151
    9,789
    May 2, 2010
    ludlow MA
    Take a look around while you are under there, if it’s due to age/cracking you will probably want to do all of them Atleast out of the valve
  9. Big Road Skateboard
    7,216
    41,007
    May 2, 2021
  10. Keepforgettingmypassword
    738
    938
    Jan 11, 2022
    I hit a small road gator
  11. Big Road Skateboard
    7,216
    41,007
    May 2, 2021
    They take out a lot. Keep a hose end repair kit in the sidebox Screenshot_20220621-210310_Samsung Internet.jpg
    Rideandrepair Thanks this.
