Brake chamber PM.
Discussion in 'Ask An Owner Operator' started by RunningAces, Nov 22, 2021.
  1. RunningAces
    RunningAces Road Train Member
    1,304
    2,581
    Jul 2, 2017
    Thinking about replacing all 6 chambers on my t680. I did have one blow out on me about 6 months ago and it ####ing sucks when it happens. Alternatively I could just change the diaphragms in them quickly and cheaply. The truck does have 500k miles on it now though and I'm thinking it's one of those things you might as well do as a PM so you don't have to cage one on the side of the road. Might also be a good idea to change those air lines to each of them while it's off.
    Thoughts on if this is just a waste of money because they can last hundreds of thousands more miles or maybe just buy a single one and keep it in the truck?
  3. abyliks
    abyliks Road Train Member
    4,112
    9,675
    May 2, 2010
    ludlow MA
    The last 30/30 can I bought was less then $40, if that’s the national debt to you replacing cans are probably the least of your worries.
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Keep a halfback and diaphragm handy on the truck, if youre going to replace things preventatively, just do all the pancakes (diaphrams).
    If the part you arent trusting is the mounting end, yes just replace all of em at one go.
    lilillill, Bean Jr. and RunningAces Thank this.
  5. RunningAces
    1,304
    2,581
    Jul 2, 2017
    Haven't looked into the price of them lately but I did hear they were north of $100 nowadays. Not a cost I can't bear but I am not looking to waste money either.
    bzinger and Bean Jr. Thank this.
  6. skallagrime
    3,855
    9,927
    Apr 10, 2012
    Indiana
    Check out napa, grabbed me 2 30/30 when i needed a few tools for my car and saw em sitting there 2 months ago, cost was 50$ ea
  7. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    I did all six on my truck this year. Also did s cams, bushings, slack adjusters, drums, shoes, bearings, hubs and caps. The whole deal. How do your s cams and bushings look? Might want to consider doing everything if you can swing the expense.
    lilillill, Pamela1990, Don379 and 5 others Thank this.
  8. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Not worry too much about steers, but would also change both hoses on each
    Pamela1990, Bean Jr. and RunningAces Thank this.
  9. RunningAces
    1,304
    2,581
    Jul 2, 2017
    Why are thr steers not a worry?
  10. lester
    2,956
    8,082
    Jan 2, 2012
    NW, Iowa
    No park brake diaphragm to leak
    Pamela1990, Don379 and RunningAces Thank this.
  11. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    You can not replace the parking diaphragm. That's the one that usually causes the trouble. Or a broken parking spring.
    From my experience, you are quite right. If one goes, the others are not too far.
    Getting stranded at the side of the road due to too much air loss and the other chambers apply the brakes can get costly.
    I did the rears all at once at some point. A few years later, they all failed again within a year.
    I do carry the rear part, a clamp and a diaphragm with me. Just in case.
    Pamela1990 and RunningAces Thank this.
