Brake issue
Discussion in 'Ask An Owner Operator' started by WesternSide, Jan 13, 2024.
  1. WesternSide
    WesternSide Bobtail Member
    I have a 16 western star 5700, recently i drove a 20 cascadia and when you press the brakes to come to a stop you can do it on one press. In my western i have to press and release multiple times for some reason if that makes any sense. They work fine but you have to press and release multiple times. What causes this?
  3. AModelCat
    163,834
    Does the truck have application pressure gauges? Should just have to press on the pedal and brakes will apply, need more brakes, press it harder.
    Without being there to actually see and experience what its doing, I would say it could be an issue with the treadle valve. That's the air valve the brake pedal actuates. If its sticking or (I think WS uses a hanging brake pedal) the linkage is binding or catching something that could cause what you're experiencing.
  4. WesternSide
    When you press on the pedal brakes apply but if you dont release and apply again I feel like the tires will lock up. Like ive tried it numerous times if i continue to press while I feel it about to lock the truck brakes lock until you release.
  5. AModelCat
    163,834
    So you just hold the brake pedal steady and the brakes gradually keep applying harder? I'd look at the treadle valve. Its supposed to regulate its outlet pressure based on how hard you press it.
  6. Spyro2112
    Spyro2112 Medium Load Member
    621
    430
    Mar 17, 2018
    Hydraulic breaks? Air n system
  7. Ridgeline
    22,701
    122,173
