brake pedal dead
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trugo, Nov 16, 2018.
  1. Trugo
    Trugo Light Load Member
    71
    50
    Dec 8, 2015
    I just bought a 95 freightliner FLD not running and towed it home. Got it running but the brakes are stuck, it wont roll. The truck builds pressure air and leaks from the secondary air system but holds in operating range while running. The hand valve will engage. But the brake pedal doesnt work, it has no pressure and does nothing. I checked the brake pedal linkage and it is connected. Ive also noticed the brake lights are stuck on. What should I look for? Im thinking I need to look at the foot pedal air valve although Im not sure how it works or what lines do what. This attached picture shows the pedal valve.
  3. AModelCat
    164,678
    Bet you the pedal is stuck on the floor or is at least partially applied.
    pushbroom and Fatboy42 Thank this.
  4. dumptruck89
    dumptruck89 Light Load Member
    79
    106
    Feb 27, 2015
    MA
    Check the plunger beneath the pedal, can almost guarantee that's your problem, dirt and moisture gets in there and binds up. Take it out clean it up lube it up and see if it solves your problem.
  5. kemosabi49
    10,977
    47,916
    Jan 13, 2013
    SW Arkansas
    Common to the FLD. On the firewall is the plunger that gets pushed in by your brake pedal. You need to take it apart and then get something to tap to plunger free.You can clean it and the bore up or buy new parts. When I cleaned mine up I always put a little anti-sieze compound on the plunger. It seemed to need it done again after a few years and seemed to only start screwing up during real cold temps.
    Rideandrepair, Dino soar and Fatboy42 Thank this.
  6. Trugo
    71
    50
    Dec 8, 2015
    Ok Thanks guys. I’ll take it apart and see.
  7. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    Had the same thing happen to my 352 in my avatar pb blaster work back and forth unstick take apart clean it up
  8. Rideandrepair
    17,561
    56,895
    Aug 8, 2015
    They give squeak when it’s real cold!!! I think you hit the nail
  9. Trugo
    71
    50
    Dec 8, 2015
    Indeed it was a problem with the plunger as kemosabi49 said. Somebody had previously greased it which was now cement. I sanded everything smooth and this worked, the brakes released and the truck drives. Thanks.
    xsetra and Rideandrepair Thank this.
