Brake problem
Discussion in 'Volvo Forum' started by waltherz, Mar 23, 2014.
  1. waltherz
    waltherz Light Load Member
    133
    13
    Dec 12, 2012
    I VAVE VOLVO 04 W/VOLVO ENGINE 465, WHEN I PUSH THE BRAKE PEDAL, TRAILER DOESN'T BRAKE. THE RED BOTTON IF I PRESS, IT NOT SEND AIR TO TRAILER'S BRAKE. I REPLACED AIR VALVE UNDER CAB (WHERE IS CONECTED BRAKE'S HOSES) AND NOTHING. ANY IDEA?
    tHANKS, WALTER
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    CK. trailer protec. valve at end of lines at rear of sleeper to see if air is back there yet?
  4. waltherz
    133
    13
    Dec 12, 2012
    I replaced. When i press the red boton isn't send air for release trailer's brake. Trailer still blocked until air get 120 psi and then it release the trailer's brake.
  5. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    Trailer protection valve is at the rear of sleeper before air lines change over to the plastic flex lines, ck. if air is back there before it gets to 120lbs.
  6. waltherz
    133
    13
    Dec 12, 2012
    I'll check again with low pressure. When i replaced that valve, before to conect all lines, i press the red boton and air get there. But after conect all lines, the air dosen't pass thru the valve to the red hose.
  7. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    It not the vavle in dash you need to CK. but the one at rear of lines under sleeper
  8. waltherz
    133
    13
    Dec 12, 2012
    tHE REAR LINE'S VALE IS NEW. DO YOU THING DASH'S VALVE IS FAILING?
  9. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    Sorry does red button pop out at low press. if not it needs new one, they can go bad.
  10. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    ? did you use a reconn. air valve when you replaced trailer pro. valve, might be bad out of box
  11. waltherz
    133
    13
    Dec 12, 2012
    Yes, both button pop out w/ low pressure.
