brake question
Discussion in 'Experienced Truckers' Advice' started by screamin eagle, Sep 6, 2015.
  1. screamin eagle
    screamin eagle Light Load Member
    103
    39
    Apr 18, 2009
    texas
    Not sure where to post this but here goes.
    I am wanting to know why the snap rings on the slack adjuster would keep breaking causing the adjuster to come loose. Rings were replaced and two days later the slack adjuster came loose again.
    any advice as to a reason is appreciated.
  3. Mr.X
    Mr.X Heavy Load Member
    737
    596
    Oct 31, 2013
    Spokane, WA
    Either not seated in the groove or wrong snap rings Im guessing. Never heard of that happening. Was the slack adjuster replaced, and then you started having the problem?
    ETA: maybe try a smaller ID snap ring.
  4. lester
    2,957
    8,087
    Jan 2, 2012
    NW, Iowa
    Proper shims and placement
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look on outside of S/cam at drum to see if the snap ring is still in place at outside of washer at bushing where you grease S cam? If missing S cam will be trying to get pushed into drum an the snap ring at adj. arm is taking all the pressure when you press on brakes, S/cam will be pushed into drum and jump off rollers inside drum, then all will have to be taken apart to fix your brake.
  6. AModelCat
    164,989
    What condition are the snap ring grooves on the end of the cam in?
  7. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
  8. screamin eagle
    103
    39
    Apr 18, 2009
    texas
    thanks for all the replies, I had never heard of this happening and as brakes being important, I think someone besides me should be trying to fix this issue.
