Brake Wear
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Smellfunny, May 6, 2024.
  1. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    I have a customer that goes through steer axle brake pads quickly. I put new drums and pads on in August of 2023 and then new pads on in Feb of 2024 and he just called and said they are cammed over May 2024. The passenger side has new spider, cam, and slack adjuster (Aug 2023). The rear pads are good and it has new brake valves on the rear (they were leaking air) Put on in Feb 2024 when the steer pads were replaced.
    This guy has a heavy foot and he hauls heavy as well, but even with that I would think the pads would last longer. 23K linings.
    2005 Peterbilt 379
  3. JB7
    JB7 Road Train Member
    1,029
    1,818
    Dec 13, 2022
    Laurel, MD
    "I put new drums and pads on..." Do you mean rotors? Pads and rotors go together and drums and shoes go together.
    "and said they are cammed over May 2024." How do disc brakes get cammed over as s-cam applies to drum brakes?
    Brakes may be dragging due to issue with calipers, hardware, sticking quick release valve. I would jack up the front, apply and release brakes, and see if the wheels spin freely.
  4. wichris
    wichris Road Train Member
    4,507
    9,281
    Jan 17, 2011
    Bobtail proportioning valve bad?
    Magoo1968 Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,774
    9,201
    Jul 12, 2017
    Engine brakes much?
    Sounds like he’s just overdriving the truck.
    Check air pressure to drives? Are the rears wearing at even close to the same rate?
  6. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Drums and shoes..
  7. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    I am pretty sure this is the issue. When he got in here he had two wheels on the trailer that were worn down to the rivets and one had cammed over. A leaking wheel seal on the drive and another wheel cammed over on the other side of drives. So basically he is go go go and not looking his truck over.
    He did not even care when I showed him the other stuff. Said he would bring it back that he had to go.
    Some of these guys are drive it until it will not go and then wonder why it will not go.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Does the truck have Q-Plus brakes?
    If they installed regular shoes, they could wear faster then cam over.
    BoxCarKidd Thanks this.
  9. Magoo1968
    Magoo1968 Road Train Member
    2,058
    5,482
    Mar 18, 2021
    St Malo mb
    Years ago I had a slack adjuster changed during my annual safety inspection. I drove roughly 1000 miles going through a city I got cut off badly and did a hard braking 30 minutes later I stopped for fuel and the wheel was smoking . Turns out the adjuster they used wasn’t compatible with the slack and would tighten if you braked hard.. something to do with new style and old style .
    BoxCarKidd and Smellfunny Thank this.
  10. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    1443 Fronts
    4709E Rears
  11. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Years ago I worked at a fleet of 9370's and 3 similar 4300's were transferred in. They were steer axle brake eating monsters.
    Learned that there is a brake porporting valve for steer axles. I thank 3 different ones with different air ratios.
    They work something like this. At 30 PSI brake application it only allows 10 to the steer. At 90 PSI application they allow 50 to the steer. At a 120 application everything is at 120. Those trucks did not have a porportioning valve on the steer axle.
    I am sure someone will come and kick my stool out from under me for incorrectness but I am just sharing the basic idea. Check your steer axle valve.
    Smellfunny and Magoo1968 Thank this.
