Brakes apply on their own
Discussion in 'International Forum' started by CMCtech, Feb 14, 2019.
  1. CMCtech
    CMCtech Bobtail Member
    28
    11
    Feb 20, 2013
    2011 International Prostar, was throwing fault codes but after recalibration on the ABS has not had a fault displayed. Rear brake lights come on, cruise goes off, slowly engages the brakes, happens when air is around 115-120 psi. Brakes are keeping the truck from running a regen. Brake switch in dash and on pedal have both been replaced. Anyone run into this issue? Driver is beyond frustrated and we have very little time to complete repairs.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Make the time to complete repairs. Or you might have to have all the time to wrap up a fatality accident because your poor tractor trailer does not understand to leave the brakes alone in winter.
    If you are a really good company, worthy of keeping good drivers YOU WILL make this load go away onto a different truck, preferably team while your driver baby sits this one at a good shop somewhere this week, hopefully not too long as necessary to solve this problem permanently so you can get back to trucking.
    Or buy older legacy equipment and be done with all that computer crap slowly throttling the life out of your drivers ability to be productive and your company's ability to stay solvent. //tease...
  4. CMCtech
    28
    11
    Feb 20, 2013
    Wow, that helped ALOT!!! Thanks
  5. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    I disagree with you often but this post is spot on... make the time before someone gets hurt or driver QUITS
    KB3MMX, fss99701 and Bean Jr. Thank this.
  6. CMCtech
    28
    11
    Feb 20, 2013
    Just reviewed the issues with our other shops and we have a plan. But if anyone has any helpful information that would be appreciated! Truck isn't a danger to anyone OTR or we would have shut it down a long time ago!
  7. Heavyd
    Heavyd Road Train Member
    7,838
    6,294
    Feb 4, 2009
    Sounds like the treadle valve itself is faulty and leaking internally.
    Humblepie, CMCtech and magoo68 Thank this.
  8. CMCtech
    28
    11
    Feb 20, 2013
    ABS Relay valve was leaking internally, problem fixed.
    KB3MMX and Heavyd Thank this.
  9. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    when you say it engages the brakes at 115+ psi system pressure, do you mean that they are engaged and the truck is undriveable?
  10. CMCtech
    28
    11
    Feb 20, 2013
    No, Brakes engage for just a second. You could hear them and see the lights.
  11. starmac
    starmac Road Train Member
    6,639
    12,529
    Apr 11, 2019
    Fairbanks Ak
    Sometimes you just have to love technology.
