Brakes Locked up on Freightliner While Bobtailing?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Proxy, Jun 18, 2020.
  1. Proxy
    Proxy Light Load Member
    165
    54
    Sep 3, 2018
    Had a driver claim the front brakes completely locked up on a 2018 Freightliner while bobtailing causing him to hook right from the middle lane right into a barrier at about a 45 degree angle and ride down the barrier for about 30 feet while still leaving skid marks...of coarse it was easy to speculate he wasn't paying attention and locked up the brakes and sent it into the barrier to avoid a collision but I want to make an informed decision so maybe you guys can give me any possibilities of this actually happening? one thing that I found interesting in the photos was that it appears only the steers locked up, only 2 tire marks from the moment the brakes locked up, no dual tire marks coming from the rear axles. Another interesting thing as well is that the ELD didn't register a hard brake which I believe monitors the speedometer over time, so if it didn't register a hard brake I'm inclined to believe the input/output shaft speed sensors and wheel speed sensors were still reading the same speed as the truck hit the barrier. No witnesses or citations given so I'm at the mercy of the rental company being honest with their investigation.
  3. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    That truck has ABS brakes.
    Nothing should have locked up.
  4. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    Driving a bobtail truck is most dangerous in my book. Very easy to hydroplane and harder to stop. Very easy to loose control during hard braking if your brakes are out of adjustment.
  5. Proxy
    165
    54
    Sep 3, 2018
    We had a KW abs module(might not be the name of it) bracket rot and the module swung down and bounced off the pavement and pulled out air lines etc and caused the truck to slow down quick and wouldn't move after, the freightliner looked violent, as if both front wheels just seized at the same time which is extremely unlikely. I don't know how a tractor reacts to locking brakes while bobtailing but wouldn't it stay straight for the most part assuming all the brakes are adjusted equally etc?
    Savage6300 Thanks this.
  6. Numb
    Numb Crusty Curmudgeon
    4,352
    10,339
    Jan 30, 2012
    Charlotte, N.Carolina
    in the days before ABS, lock up the brakes and you never knew where you were going to end up.
    they never have the same traction or brake power.
    you'd pump then let off, correct direction, repeat.
    do it bobtail and I've seen go into a violent spin.
    cabovers were the most dangerous.
    p608, Tb0n3, Dino soar and 5 others Thank this.
  7. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    If all components of ABS working properly. Bad wire connection or bad ABS solenoid can change your life in one second.
    The idea is good but wiring, connectors, valves are crappy.
    Wanna ask me how do i know?
    stillwurkin, tommymonza and Numb Thank this.
  8. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Do 2018 trucks have spring brakes in front. Or some sort of hill assist that applies the brakes?? If not driver needed to apply brakes hard enough to lock them with a faulty abs system . Or brake treadle valve took a dump and diverted air to brakes but without him pushing the pedal ABS didn’t know it was needed due to no brake light signal ..
    tommymonza and Proxy Thank this.
  9. Savage6300
    Savage6300 Bobtail Member
    5
    Jun 18, 2020
    Harrisburg, PA
    Kind of makes me wonder if his steering linkage broke and slammed one of his wheels against the steer stop.
    Proxy Thanks this.
  10. xsetra
    xsetra Road Train Member
    5,198
    7,150
    Aug 21, 2011
    Post the pictures.
    Good employee? Keep
    Bad employee? Layoff no truck to drive.
    I doubt anything the driver could have done to get steers only to lock up.
    Even a hard brake you'll wheel hop the drives. My opinion.
    Good luck
  11. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Yeah, having a hard time figuring out how it would even be possible to lock the steers only when bobtail, unless something broke/quit working. That's where all the weight and traction is.
    tommymonza, xsetra and Proxy Thank this.
