Brakes surging while driving. Peterbilt 348. Help!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Davis42200, Nov 22, 2024.
  1. Concorde
    Concorde Road Train Member
    5,506
    19,606
    Jun 29, 2016
    West Melbourne Florida
    Your problem is the traction control. If the ATC light is on then a technician should be able to solve the problem.
    What you described sounds like what I get when I take a certain curve in Idaho a little faster than the truck approves of. It’ll go in panic mode and jack the brakes a couple times.
    JB7 Thanks this.
  3. Davis42200
    Davis42200 Bobtail Member
    36
    4
    Dec 7, 2020
    Insite works on my engine. It's a paccar PX-8. You might think Davie but it's insite because it uses Cummins controller. I will try what you said in the morning.
  4. Davis42200
    36
    4
    Dec 7, 2020
    Yes that's exactly what happens. But I'm not driving aggressively at all.
    Concorde Thanks this.
  5. Concorde
    5,506
    19,606
    Jun 29, 2016
    I’m definitely no mechanic, just sounds the same as mine. But mine is functioning properly.
    I’m guessing it’s probably whatever sensor or gyro that measures how much you’re leaning in the curves.
  6. AModelCat
    165,108
    Insite is diagnostic software for the engine. It most likely will not read much of anything off the rest of the modules in the truck, which are the ones you need to see the information off of.
  7. JB7
    JB7 Road Train Member
    1,044
    1,844
    Dec 13, 2022
    Laurel, MD
    Traction control works off of the ABS sensors that monitor each wheel. If a wheel is locking up the sensor notifies the controller/valve to release/pulse the brake application. If it senses spinning then it will apply/pulse the brake. Check all your wheel seals to make sure they are not leaking. If you have a wheel that is loose, as previously mentioned by Goodysnap, then a seal would most likely be leaking. Also check the wires from the sensor at each wheel back to the valve. Make sure that none of the wires rubbed anywhere and that none of the connections are corroded.
  8. Davis42200
    36
    4
    Dec 7, 2020
    I found this on the manual. Could it be stability control, steering angle sensor or, yaw?
  9. Davis42200
    36
    4
    Dec 7, 2020
    I think the ESC needs to be disabled. This truck had a roll-off hoist and a tag axle mounted. The manual says if anything like this is added, then ESC needs to be disabled.
  10. Goodysnap
    Goodysnap Road Train Member
    3,779
    9,212
    Jul 12, 2017
    I have ran into this. Mostly after an engine software update. Every time the unit has active ABS/TCS lamps on. You didn’t mention any active faults/ lights?
    The ESC parameter will become enabled in Bendix. Disabling it corrected the issue.
    You really need Bendix A com. Assuming it’s a Bendix equipped truck which 95% are.
  11. JB7
    1,044
    1,844
    Dec 13, 2022
    Laurel, MD
    To Goodysnap: Post #2 from OP has a pic of the light.
    OP: you need to get the code/s otherwise you are only guessing. Any codes will point you or a tech in the right direction.
