The light on the switch does not indicate a fault. A fault lamp ABS or TCS will be displayed on the information center or Paccar display center of the dash cluster
Brakes surging while driving. Peterbilt 348. Help!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Davis42200, Nov 22, 2024.
Page 3 of 3
When the problem occurs I have no faults on the dash. I have no faults at all really. This morning I pulled the ABS fuse. Which put an ABS and traction control fault on the dash for the first time.
Drive the truck and see if you can duplicate it. My guess is it will not do it when disabled.
That's the plan today. Do you know if The stability control esc is tied in with the abs/atc system? I cannot find any fuses for ESC
Yes, ESC is integrated into the ABS system but with additional sensors such as yaw, steering angle, lateral acceleration. Failures in ESC can be attributed to ABS or ATC malfunctions. I would turn off the ATC and drive to see if the problem still occurs. Regardless of what the dash is saying (no faults) I would still want to connect a laptop or scan tool, and with Bendix software, to see if any faults or anything out of spec is happening.Goodysnap Thanks this.
With no faults the system is activating stability or traction control when it’s not needed.
Thats why I asked if the brake pedal may be stuck slight. Without the brake pedal being applied it’s not going into an ABS event.
Either way, a wheel end or wheel speed sensor issue is the most likely root cause of the problem at hand. The ABS controller is likely just doing what it’s told to do. -
So I've been driving all day today and pulling the abs fuse seems to have eliminated the problem. Just so I'm getting this right. The software to disable the stability control and diagnose any other issues is Bendix? I just want to make sure because my mechanic had insite hooked up and working which had a load of parameters available but I didn't look for ESC at that time.
Yes correct.
Simply disabling the stability control on a truck that is equipped may cause other codes to show in engine or trans. But it may help narrow down the issue.
Bendix tech help is also a great resource
1800 AIR BRAKE -
The owners manual for this truck specifically says the stability control need to be disabled if anything is added to the chassis
Page 3 of 3
