Happy July,
So I'm having a problem with brake adjustment... I don't understand fully on how to tell.. any help would be great..
brakes....
Discussion in 'Questions From New Drivers' started by TruckerPete1990, Jul 1, 2013.
Problems with the slack holding adjustment and pushrod travel? Release your brakes, mark the pushrod, apply 90psi, check travel. To see if the slacks are adjusting properly back on off, and have a partner apply the brakes repeatedly to 90 psi. Leave the wrench on the nut and watch for the wrench to turn no turning equals a bad slack. Should adjust all the way back. Do not ask me legal spec on the pushrod travel as different chambers have different acceptable strokes. After we know your chambers we can help you with the correct stroke. As for adjusting need the brand of slack for proper adjustment procedure.TruckerPete1990 Thanks this.
Weirdest thing happen today to me. Backed into the dock was getting loaded and I slid forward.. this was flat ground concreate . Unloader had to get me to back up again lol..
Do both of your drive axles have spring brakes? On mine its just the front drive with spring brakes and my truck tends to roll forward at times as well when parking on hills even with the slacks in adjustment it will hold after pulling the trolley bar and releasing it but it does make me worry at times. I'd say start by adjusting your slacks as that also effects the park brakes. Could also be on the trailer if your trailer was set. I remember when I had one that was bad on my flat it had almost 4" of travel and I had to almost stand on the pedal to stop when that thing was out of whack. Have you noticed increased braking effort at all?
This was my escapade when it was out. No it ain't just the game that sob was bad lol. -
Only got spring on rear drives. And yea a little but I always change trailers. Prob don't help abs light on for trailer..
Thank you helps .
U mean you picked up a trailer the light actually worked on? Lmfao we unplug those #### things all the time hahaha.
Oh light is unplugged but shows on dash lol
379exhd Thanks this. -
Oh we take care of those 2 black tape or rip the dash out and take the bulb out lol. Out of all the dummy lights on a truck a dummy had to come up with that one!TruckerPete1990 Thanks this.
