brakes....
Discussion in 'Questions From New Drivers' started by TruckerPete1990, Jul 1, 2013.
  1. koncrete cowboy
    koncrete cowboy Medium Load Member
    638
    331
    Jun 11, 2013
    Pennsylvania
    Easiest way .....lift the rears off the floor release the brakes spin the tires and run the slacks in untill you just startfeeling drag and back off 1/4turn.repeat ......of course im in the shop so its a little easier....
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    there's been a couple of times where i've parked the truck. only to have it start rolling.
    i just simply crawl underneath. look for the gaps between the brakes and drums. and adjust.
    i don't crank em down. but just to the point where it starts to get harder.
    no more rolling till the brakes wear down again.
    once i'm back in the yard. i argue with the mechanics becuase they don't see the gap. well, duh. i don't drive with brakes out of adjustment.
    that one particular truck didn't have a brake gauge on the dash. cuz that's what i normally look at for brakes out of adjustment. when the pressure gets a little higher. brake adjustment is the first thing i look for. and that's usually the problem.
    and that was a nice little chart that was posted.
    but i don't think it matters what chamber is on there. dot basically looks for that 2 inches of stroke. anything over that and your OOS.
    properly adjusted brakes and you don't usually exceed 1 inch.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    trailer moving forward at dock probaly had more to with suspension having a auto dump valve they will walk forward 6 inches or so sometimes
