Brakes
Discussion in 'Questions From New Drivers' started by DexterSaintJock, Dec 4, 2023.
  1. SmallPackage
    5,827
    18,677
    Dec 20, 2019
    Marion Texas
    There have been plenty of “brake failure” accidents with no fade or fire or a system that maintains pressure so the fail safes don’t get triggered. Treadle valves or relay valves are the culprit. Foot pushes peddle and valves give no response to move air and the rest is history. All you can do is pull the emergency ( that is why the knob still says emergency on it) try like heck to down shift and not stall and hope for the best. That has got to be the scariest ride ever.
    Chinatown Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    78,077
    186,247
    Aug 28, 2011
    Henderson, NV & Orient
    Steady pressure also prevents oxygen from getting between the brake pads and drum and that's why there's no fire. Maybe a little smoke sometimes, but no fire.
    tscottme Thanks this.
  4. 77fib77
    77fib77 Road Train Member
    11,768
    77,999
    Jul 7, 2010
    St Louis
    If your blue line breaks it can be really bad.
  5. tscottme
    tscottme Road Train Member
    The most common experience is overheating the brakes due to faulty brake adjustment or mis-use of brakes when descending steep hills/mountains. As jake brakes became more common and used, CDL schools and company trainers just assume the newbie already knows how to properly use one or that jake-brake equals safety so turning on the switch equals adding safety, like EVERY newbie and their stupid 4-way flashers. "keep doing what you are doing but throw on your 4-ways and now you are safer."
    201 Thanks this.
  6. DexterSaintJock
    DexterSaintJock Light Load Member
    181
    86
    Nov 16, 2023
    Montebello, California
    LOL
