Brakes
Discussion in 'Questions From New Drivers' started by soisauz, Aug 2, 2014.
  1. bigdogpile
    bigdogpile Road Train Member
    1,931
    1,463
    May 16, 2010
    fontana ca
    Yo Frank-Tank ...How the heck is it you dont know if you have drums or discs..Dont you look at your brakes everyday during a pre-trip..disc are very rare,but you would know instantly if you had them just by looking at them...
  3. BROKENSPROKET
    BROKENSPROKET Medium Load Member
    675
    172
    Jan 22, 2011
    Wisconsin
    He didn't say that he didn't know the difference. He said that he didn't know if that difference was the reason for the sound.
  4. Brandt
    Brandt Road Train Member
    4,635
    6,376
    Sep 17, 2012
    If your truck has the applied air brake pressure gauge, all you need to figure out it the 10psi reading on the gauge. You can apply 10 psi to the brakes all day and the drums will not overheat. So basically you go down hill in any gear with and weight that the brakes can hold with a 10psi or less. You ride the brakes all the weather down the hill at 10psi. If the brakes can't hold the truck back with 10 psi, then you need to drop a gear.
  5. Brandt
    4,635
    6,376
    Sep 17, 2012
    Also look in mirrors and if you see brakes smoking your going to fast.
  6. bigdogpile
    1,931
    1,463
    May 16, 2010
    fontana ca
    ah OK that makes sense
  7. Calregon
    Calregon Light Load Member
    170
    106
    Dec 8, 2013
    Oregon
    I also pull a flatbed, and am new at it. I thought my brakes sounded weird when I first started. I noticed in traffic that many truck brakes make different sounds. I would think that you would hear air from your glad hand area or notice the rubbers need to be changed ( I always carry a few ) if that was a problem. Do you use the same trailer all the time? I get the abs lite on different trailers sometimes. Like someone else said start down the hill in a lower gear than you think. Easy to go up a gear. You probably know more than me but, Ill just remind you to do your inter trips and check your securement good. As you know loads settle. Tighten that $#!&. It would suck to have something shift on a downhill curve.
  8. Bigchevy
    Bigchevy Light Load Member
    217
    82
    Jul 29, 2013
    colorado
    I run vail pass all the time at 75-80k the speed limit is 45, I go down in 8th for most of it with Jake's on 3. I drive a kw 660 with a 10 in it.
  9. MACK E-6
    50,173
    239,763
    Your boss is a smart man.
