Braking my head
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by thecubantrucker, Oct 10, 2024.
  1. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    Alright mechanics good afternoon starting off freightliner century detroit 60 series 12.7 . Prior you my new inframe rebuild which I got 5k miles on my my temperature driving under load even pulling from 0 to start driving will start gradually to climb up some times when pulling a load uphill it goes all the way to 211 to 215 I hit fan clutch at at about 205 and it will still climb will gradually start coming down a little . It's got fresh inflame with new head , new radiators , new waterpump about 1 year ago new thermostats new temp sensor new fanclutch as well I made sure no air pockets are present I'm loosing my mind already new temp gauge as well
  3. DUNE-T
    DUNE-T Road Train Member
    7,046
    17,162
    May 10, 2015
    Detroit, MI
    So, what's the problem?
    Rideandrepair Thanks this.
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,927
    Apr 10, 2012
    Indiana
    I THINK he means hes worried hes overheating, dont know when the fan temp switch is supposed to kick in on those detroits automatically
  5. thecubantrucker
    149
    92
    Jun 2, 2019
    The problem is that temp fluctuations like that aren't normal and I'm afraid of overheating the fan clutch kicks on about 208
  6. Concorde
    Concorde Road Train Member
    5,482
    19,473
    Jun 29, 2016
    West Melbourne Florida
    Temp sounds normal to me. Flat roads mine will run 181-183. Climbing if it’s a decent sized climb it’ll go right to 210 and kick on the fan automatically. Normally I just turn the fan on manually around 190 or so. Even if I don’t catch it until 200 it’ll take a few seconds to reverse the temp.
  7. Concorde
    5,482
    19,473
    Jun 29, 2016
    What’s your normal temp running flatland?
  8. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    bad boost leak or junk turbo
  9. thecubantrucker
    149
    92
    Jun 2, 2019
    Running flat under load at times it stays at 187 but jumps to 200 easy
    Rideandrepair and Concorde Thank this.
  10. thecubantrucker
    149
    92
    Jun 2, 2019
    Funny you say that I just replaced turbo 2 days ago brand new as well
  11. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    Why not take it back to the shop that did the work and ask them?
