Brand New Flat-Bedder Here!
Discussion in 'Flatbed Trucking Forum' started by Antler24, Apr 9, 2017.
  1. Antler24
    Antler24 Light Load Member
    98
    124
    Mar 1, 2017
    So I've got about 6yrs total driving experience but been out of the seat for just about 4yrs. Decided to get back at it with a long haul flat bed company. Start Tuesday morning got 3-4 days with a local driver to learn some tarping and securement, then I get my own rig and head OTR.
    I've read the tips/tricks and the terminology threads, and even looked through the load pic thread for examples. Being new to flatbed I've got alot to learn and am reading everything I can here.
    Any other advise?
  3. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Dont accept hide loads. (Unless your mj.) Ask, ask, ask.
    Thats bout it.
    Oh, one more thing. Dont tell any non flatbeder how fun it is. We like our secrets, secret.
    spyder7723, Lepton1, fargonaz and 11 others Thank this.
  4. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,919
    Dec 12, 2015
    There's legal. And there's common sense. And there is self preservation.
    Say you had a 10,000 pound chunk of steel. 4'x4'x4'. Legally you need 2 straps on it. Common sense would be 2 chains. Self preservation would be two chains, then 2 "X" chains on the front of it.
    There's no such thing as a stupid question. Ask away. These guys have more cards up their sleeves than there are cards in the deck.
  5. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    Steel and concrete are danderous. Once you've seen them move forward on a trailer it makes you use more securement.
    Crusader66, Lepton1, RStewart and 3 others Thank this.
  6. Hick
    Hick Heavy Load Member
    928
    1,624
    Dec 4, 2014
    Once you get some experience you will be able to pull off cool moves like this:
    Steer high!
    Crusader66, Lepton1 and FerrissWheel Thank this.
  7. FerrissWheel
    FerrissWheel Road Train Member
    2,007
    6,019
    Dec 23, 2015
    NV
    Use thine squishy brain device.
    Be methodical. Don't cut corners out of impatience.
    Had a driver recently dump some chassis. Because they took thier chains off and didn't put them back on before having to reposition for the wrecker.
    Crusader66, TripleSix and x1Heavy Thank this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    My stragety is to throw everything on it until I run out of securement or points to tie to. It takes a little bit longer but the value is my philosphy that God can pick up the truck turn it upside down while playing and the load will stay on the deck.
    Crusader66 and FerrissWheel Thank this.
  9. MACK E-6
    50,029
    238,312
    You have a good, knowledgeable bunch of drivers here who are willing to help any way they can.
    Any questions at all, don't be afraid to ask.
  10. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Best advice is to ask questions and then when loading,.. look for someone who looks like he has his ish together. Not the 2 guys joking around and not taking things seriously. There are many shortcuts and different ways to do the same thing. Everyone has what works for them. Just because you do it differently does not always make it wrong.
    Watch and observe. Learn to use a bulk head when ever possible. Or at the very least,.. add securement that will block forward movement. This is a self preservation task that not everyone uses. Last thing you want is that load to come crashing through the back of your tractor, killing you.
    Fatality:
    Fatality:
    Fatality:
    Things happen. With open deck your cargo is out there for all to see. Constant vigilance is needed. Not trying to discourage you. Only to make you aware of what can happen. You need common sense when doing open deck. There is no room for ignorance. Each of the images above could have been prevented had the loads been properly secured. Never become complacent or take anything for granted. The trailer will flex, chains and straps can and do come loose. This is why you often see open deck drivers in rest areas or on an off ramp somewhere checking over his load. I typically check mine after the first 30 mins. Then again 1 - 2 hrs and every 2 hours after that. The 5 mins you took to stop and check could not only save your life,. but an innocent motorist as well.
    Many examples of good and bad securement here if you want to search for them.
    @Chewy352 is a prime example of a successful transition to open deck.
    Hurst
  11. Espressolane
    18,678
    117,061
    Think about this for a moment
    Any load can shift, move, roll, twist.
    The thing you are looking to do is stop that potential before it starts. It is a lot easier to keep it still, than stop it.
    physics wins all the time, every time.
    Bulkheads, cross chains, trip chains and blocks are just some of the tools you have available to you.
    another thing to think about.
    With a strap, the maximun clamping force is the section between the winch and the first change of direction.
    Chain works the same.
    A 90 degree corner can cut your clamp force by as much as 40 percent.
